ASA 5506 - Need help routing traffic between sub interfaces
Gary Culler
Need assistance with routing network between sub interface on the ASA.  Right now, all my devices are in the infrastructure subnet (192.168.100.0/24) b/c i can't figure out how to get the ASA to route traffic between the vlan's on the sub interface.  Looking for some asssistance.
The ASA is connected via a 802.1q trunk on Gig 1/2 to my switch.  The ASA is the default gateway for all the VLAN's.  I want to allow traffic all traffic between networks 192.168.100.0/24 -  192.168.130.0/24.  The guest netwok in (192.168.190.0/24),  i only want to allow DHCP/DNS to 192.168.100.10.  I could continue to use the ASA for DHCP/DNS for just the Guest network but my goal is to create a single point of administration from a DHCP/DNS perspective.
Eventually i would like to move my DHCP server to the Server network (192.168.110.0) if I can finally get traffic allowed between the various networks.  Can anyone please provide the commands to make this happen???
Below is my ASA config.  I can post the switch config if needed but it's just a 802.1q trunk allowing all VLAN's.  I have created SVI's for each network on the switch (192.168.x.4) and a layer 2 vlan for each network.
: Serial Number: <removed>
: Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.3(2)2
hostname <removed>
enable password <removed> encrypted
names
ip local pool vpn 192.168.1.200-192.168.1.220 mask 255.255.255.0
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address dhcp setroute
interface GigabitEthernet1/2
 description LAN Connection
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/2.100
 description infrastructure
 vlan 100
 nameif infrastructure
 security-level 100
 ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet1/2.110
 description server
 vlan 110
 nameif server
 security-level 100
 ip address 192.168.110.1 255.255.255.0
interface GigabitEthernet1/2.120
 description clients
 vlan 120
 nameif clients
 security-level 100
 ip address 192.168.120.1 255.255.255.0
interface GigabitEthernet1/2.130
 description vpn
 vlan 130
 nameif vpn
 security-level 90
 ip address 192.168.130.1 255.255.255.0
interface GigabitEthernet1/2.190
 description guest
 vlan 190
 nameif Guest
 security-level 50
 ip address 192.168.190.1 255.255.255.0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
boot system disk0:/asa932-2-lfbff-k8.SPA
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network INSIDE_HOST
 subnet 192.168.1.0 255.255.255.0
object network <removed>
 subnet 198.200.139.0 255.255.255.0
 description <removed>
object network infrastructure
 subnet 192.168.100.0 255.255.255.0
object network clients
 subnet 192.168.120.0 255.255.255.0
object network vpn
 subnet 192.168.130.0 255.255.255.0
object network Guest
 subnet 192.168.190.0 255.255.255.0
object network server
 subnet 192.168.110.0 255.255.255.0
access-list outside_access_in remark all connections for IP phone
access-list outside_access_in extended permit ip object <removed> 192.168.1.0 255.255.255.0
no pager
logging enable
logging asdm informational
mtu outside 1500
mtu infrastructure 1500
mtu server 1500
mtu clients 1500
mtu Guest 1500
mtu vpn 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
 nat (infrastructure,outside) dynamic interface
 nat (clients,outside) dynamic interface
 nat (Guest,outside) dynamic interface
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.100.0 255.255.255.0 infrastructure
http 192.168.110.0 255.255.255.0 server
http 192.168.120.0 255.255.255.0 clients
no snmp-server location
no snmp-server contact
snmp-server community *****
service sw-reset-button
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
 no validation-usage
 crl configure
crypto ca trustpoint ASDM_Launcher_Access_TrustPoint_0
 enrollment self
 subject-name CN=<removed>,CN=<removed>
 crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate <removed>
  quit
crypto ca certificate chain ASDM_Launcher_Access_TrustPoint_0
 certificate 8<removed>
 quit
crypto ikev2 policy 1
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 enable outside
crypto ikev2 remote-access trustpoint ASDM_Launcher_Access_TrustPoint_0
telnet timeout 5
no ssh stricthostkeycheck
ssh 192.168.100.0 255.255.255.0 infrastructure
ssh 192.168.110.0 255.255.255.0 server
ssh 192.168.120.0 255.255.255.0 clients
ssh timeout 60
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd address 192.168.100.50-192.168.100.150 infrastructure
dhcpd address 192.168.110.50-192.168.110.150 server
dhcpd address 192.168.120.50-192.168.120.150 clients
dhcpd address 192.168.190.50-192.168.190.150 Guest
dhcpd enable Guest
dhcpd address 192.168.130.50-192.168.130.150 vpn
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_Launcher_Access_TrustPoint_0 infrastructure vpnlb-ip
ssl trust-point ASDM_Launcher_Access_TrustPoint_0 outside
webvpn
 enable outside
 anyconnect image disk0:/anyconnect-macosx-i386-4.1.02011-k9.pkg 1
 anyconnect profiles <removed>
 anyconnect enable
 tunnel-group-list enable
 error-recovery disable
group-policy <removed>
 wins-server none
 dns-server value 8.8.8.8 8.8.4.4
 vpn-tunnel-protocol ikev2 ssl-client ssl-clientless
 default-domain none
 webvpn
  anyconnect profiles value <removed> type user
dynamic-access-policy-record DfltAccessPolicy
username <removed> password <removed> encrypted privilege 15
tunnel-group <removed> type remote-access
tunnel-group <removed> general-attributes
 address-pool vpn
 default-group-policy <removed>
tunnel-group <removed> webvpn-attributes
 group-alias <removed> enable
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
 class class-default
  sfr fail-open
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
Cryptochecksum:<removed>
: end
5 Replies 5
Andre Neethling
Level 4
Level 4
Everything looks OK. For the DHCP of the guests you can add an ACL to permit bootp and dns and apply it inbound on the guest interface.
enable DHCP relay.
dhcprelay server <IP of Server> <interface name where server is>
dhcprelay enable Guest
I browsed through it very quickly, and the rest of your config looks ok. Just a question............ what is the purpose of the VPN interface?
Hey Andre,
Routing between networks in the sub interfaces is not working
I tried these commands & it's working somewhat but not everything.  Ping between all subnets is working but i can't SSH or HTTPS to my devices on different subnets for reason.. but I can RDP from a device in the client subnet to a device in the server subnet...???  but that same device in the client subnet cant' SSH or HTTPS to the WLC in the server subnet??? it's really odd.
object network obj_nat_infrastructure
object network obj_nat_server
object network obj_nat_clients
object network obj_nat_vpn
nat (infrastructure,server) source static obj_nat_infrastructure obj_nat_infrastructure
nat (infrastructure,clients) source static obj_nat_infrastructure obj_nat_infrastructure
nat (infrastructure,vpn) source static obj_nat_infrastructure obj_nat_infrastructure
nat (clients,infrastructure) source static obj_nat_clients obj_nat_clients
nat (clients,server) source static obj_nat_clients obj_nat_clients
nat (clients,vpn) source static obj_nat_clients obj_nat_clients
nat (vpn,infrastructure) source static obj_nat_vpn obj_nat_vpn
nat (vpn,server) source static obj_nat_vpn obj_nat_vpn
nat (vpn,clients) source static obj_nat_vpn obj_nat_vpn
nat (server,infrastructure) source static obj_nat_server obj_nat_server
nat (server,clients) source static obj_nat_server obj_nat_server
nat (server,vpn) source static obj_nat_server obj_nat_server
Is there a reason why you have NAT rules between your client, infrastructure and server vlans? You don't need to NAT between them, and it's probably better if you don't.
Remove the NAT rules between those interfaces, then test again.
Do you have communication between your DHCP/DNS and the guests?
Aaron Ekinaka
Gary-
Did you ever get this solved. We have a couple dozen ASA5506's deployed and the need has come up for using subinterfaces. I'm curious if you were able to get this working properly.
Unfortunately, there isn't a lot of real-world documentation / forum examples of these kinds of things on the 5506 platform.
Hello Aaron, what is your particular need with the use of subinterfaces? I may be able to assist you.
