ASA 5520 problems with alias, static and nat
networkingib
Hi all,
I have three networks, inside (security 100), dmz (security 50) and outside (security 0).
And I have a static nat to permit access from outside to a web server in dmz
static (dmz,outside) Public_IP DMZ_WEB_SERVER_IP netmask 255.255.255.255
I have configured de access-list to permit all and:
I can do ping from inside to the web server?s dmz_ip.
I can do from any external IP to the web server?s public_ip
But I can?t do ping from inside to the web server?s public_ip
So, I have try with alias:
alias (inside) Public_IP DMZ_WEB_SERVER_IP 255.255.255.255
And then I can do ping from inside to the web server?s public_ip
But I can?t do ping from inside to the web server?s dmz_ip
I have try whit static too:
static (dmz,inside) Public_IP DMZ_WEB_SERVER_IP netmask 255.255.255.255
But the result is the same than with alias. Any idea?
Fernando.
a.kiprawih
Level 7
Level 7
Your config looks ok. BTW, are you configuring this with or without DNS around, i.e with external DNS?
IF you already tried (but unsuccessful) with the following commands (in pair):
alias(inside) Public_IP DMZ_WEB_SERVER_IP 255.255.255.255
Then, for testing purposes only, try to map inside & DMZ using static:
static (inside,dmz) inside_subnet inside_subnett netmask inside_netmask
i.e:
static (inside,dmz) 10.1.1.0 10.1.1.0 netmask 255.255.255.0
*where 10.1.1.0 is your inside segment (/24)
Try to ping/access DMZ_WEB_SERVER_IP with its actual IP from inside. Make sure if you have ACL on the Inside interface, allow www access to the DMZ web server.
Example - look under "Translate a DMZ Address with Destination NAT:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aee.shtml
The DNS is an external DNS in internet.
#Then, for testing purposes only, try to map inside & DMZ using static:
#static (inside,dmz) inside_subnet inside_subnett netmask inside_netmask
I did it before open this post and with it done inside network is available to comunicate with dmz network but then I can't connect from inside network to the Public_IP
I would like to be able to connect to the DMZ_WEB_SERVER trough the internal IP and the DNS name, for example www.realwebserver.com.
I have been looking for a solution in a lot of web sites but I don't have find nothing that confirm if it is possible or not.
Do you know it?
Regards and thanks for your post.
Not that I know, except that the above Cisco link (look under Translate a DMZ Address with Destination NAT) provide config guide for Inside hosts accessing DMZ's webserver via it's internet name (combination of alias & static).
