ASA 5540 does not see USB flash
Grishazahid
Greetings!
Do ASA 5540 has USB flash support? There are two usb ports on back side of ASA. I plug in USB flash and enter the next:
ciscoasa# dir disk1:
%Error opening disk1:/ (No such device)
Firmware file is asa917-29-k8.bin
The same USB flash works with ISR 2911 correctly.
Looking at the following - https://www.cisco.com/c/en/us/td/docs/security/asa/hw/maintenance/guide/asa_hw/overview.html#wp1052511
I don't think USB is supported on your model actually.
Management port1
6
USB 2.0 interfaces2
11
VPN LED
External CompactFlash slot
7
Network interfaces3
12
Flash LED
Serial Console port
8
Power indicator LED
13
AUX port4
Power switch
9
Status indicator LED
14
Power connector
Power indicator LED
Active LED
1.The management 0/0 interface is a Fast Ethernet interface designed for management traffic only.
2.Not supported at this time.
6 Replies 6
GRANT3779
When I have issues with this, it tends to be hit or miss depending on the USB drive model. I'm assuming it is formatted correctly since it works on the router.
On the ASA, when you insert the FLASH Drive, check the logs of Firewall, should indicate where the issue is -
show logging
USB needs to be set to FAT format too, 32 or 16 should work
Usb was formatted in fat first and then in fat32 (uning windows diskpatr utility). Logging to console was enabled too
Spoiler
ciscoasa(config)#logging enable
ciscoasa(config)#logging monitor 7
ciscoasa(config)#exit
ciscoasa# dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
disk0: Directory or file name
disk1: Directory or file name
flash: Directory or file name
system: Directory or file name
<cr>
ciscoasa#
is this the normal output of "dir"? Nothing happens when i connect usb flash, no logs.
Or there is some command that enables usage of usb ports?
On your model of ASA Disk 1 will represent the external storage.
No Output from
show disk1:
or
dir disk1:
Compact flash is not inserted in slot
ciscoasa# show disk1:
%Error show disk1: (No such device)
Usb flash is inserted in usb slot.
I make even more research and  get ASA 5510. firmware asa825-59-k8.bin. Symptoms are the same
Management port1
6
USB 2.0 interfaces2
11
VPN LED
7
Network interfaces3
12
Flash LED
Serial Console port
8
Power indicator LED
13
AUX port4
Power switch
9
14
Power connector
Power indicator LED
Active LED
