ASA Management Interface access problem
randyclark
Level 3
Level 3
I have the management interface connected to the network and set to manage only. I can access the ASA from the subnet it in, but not the rest of the network. I have the access rights for the subnet I'm trying to access the the ASA set for HTTPS and Telnet for the management interface. I also have the subnet set to access the ASA from the inside interface and that works. Why can't I access the ASA through the management interface even with the subnet allowed?
spremkumar
Level 11
Level 11
Hi Randy
Can you post the configuration which you have done over there ?
Pls do note that you wont be able to telnet the security device from the outside interface.
But you can do SSH from the outside interface.
You can telnet/ssh onto the router from the inside interface..
regds
