ASA Routing/NAT problem
Chewbakka1
I have an ASA running 9.7 which has a public ip (222.222.222.222) assigned to its outside interface and a default gw pointing to the first address in the 222.222.222 -network.
I then route another subnet (123.123.123.192/26) to the ASA's outside address.
When i try to perform dynamic nat (PAT) for one of the  inside interfaces to one of the public ip's in the 123.123.123.192/27 range, no traffic is passed, even though i can see the states being created and ARP entries in the router.
The 'permit arp not-connected' feature is turned on.
When changing the object nat to the outside ip 222.222.222.222, traffic flows without any problem.
Any idea why this is?
6 Replies 6
Hassan Chalabi
subnet (123.123.123.192/26) is public IP? is it known to your ISP?
Yes.
check the gateway of 123.123.123.192/26 if it is reachable, I am assuming this is a secondary subnet from the ISP that comes from the same interface of the edge router to the outside interface of the FW.
The gateway of 123.123.123.192/26 is reachable. And yes, the subnet comes in on the same (outside) interface to the ASA.
can you post packet tracer output?
run one from an inside ip icmp to 8.8.8.8 after you NAT to the secondary subnet.
something like:
ASA#packet-tracer input inside icmp 10.0.0.1 0 0 8.8.8.8
Interface names and public ip's have been changed to obscure the original customer
packet-tracer input inside icmp <inside-ip> 0 0 8.8.8.8
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
found next-hop 222.222.222.1 using egress ifc Outside
Phase: 3
Type: NAT
Subtype:
Result: ALLOW
Config:
object network INSIDE-OUTSIDE-NAT
 nat (INSIDE-INTERFACE,OUTSIDE) dynamic
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Result:
input-interface: <Inside-interface>
input-status: up
input-line-status: up
output-interface: Outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (nat-xlate-failed) NAT failed
