ASA to FTD using FDM for Management
mumbles202
Level 5
Level 5
I know you can go from ASA to FTD using the migration tool if you're going to be managing the box via an FMC, but if the current infrastructure only supports Hyper-V i think you need to use the FDM instead.  Is there a way to go from ASA code to a FDM managed FTD other than manually configuring the new FTD appliance?  Even if it's via CLI.
Rahul Govindan
There is no migration tool to migrate the ASA config to FDM as of today. Also FTD CLI is locked from manual configuration via CLI. You can however use API's to add configurations directly into the FDM managed FTD devices. This may help if you have a lot of rules/config that you need to migrate to the FTD.
