ASA5505 ASDM 7.1.(5)100 - Java 7U51 problem?
Hello
Place can anyone help?
I'm running ASA5505 with:
Cisco Adaptive Security Appliance Software Version 9.1(4)
Device Manager Version 7.1(5)100
Recently upgraded, also my Java (Win7) was upgraded to 7U51
No longer able to access the ASA with ASDM
Neither with launcher nor webstart.
Anyone
(Please feel free t ask for more info)
hkl
prateeve
Level 5
Level 5
Hi Kristian,
There is a bug with cisco wherein java 7 update 51 causes the problem with ASDM access. The bug id is CSCum46193.
I would suggest you to downgrade to java version to java 7 update 45 and it would work.
- Prateek Verma
6 Replies 6
johnlloyd_13
Level 11
Level 11
Could you try downgrading your Java to version 6 or the previous one when it was still working?
Hello
Thanks for your responce. Did a downgrade to Java 7U45 as suggested by Prateek
Work like a charm.
hkl
prateeve
Level 5
Level 5
Hi Kristian,
- Prateek Verma
Ptrateek
Thanks, work like a charm
hkl
Hello Prateek (or anyone else who can help)
As stated in my last post here, it work fine. However trying again today, it's broken again, checked my java version and it's still 7u45. (ASDM is 7.1.5-100)
Tried on another machine with the workaround in CSCum46193, this machine with Java 7u51.
ASDM is 7.1.5-100
security exception for ASA's IP is addeed in java cpl
Any ideas?
hkl
Here is the log from the Java console
Using JRE version 1.7.0_45 Java HotSpot(TM) Client VM
User home directory = C:\Users\hklarsen.hkl-win7-dell
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
q:   hide console
s:   dump system properties
Application Logging Started at Sun Feb 16 10:25:30 CET 2014
Local Launcher Version = 1.5.69
Local Launcher Version Display = 1.5(69)
OK button clicked
Trying for ASDM Version file; url =
https://192.168.1.1/admin/
java.net.SocketException: Unexpected end of file from server
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(Unknown Source)
at com.cisco.launcher.y.do(Unknown Source)
at com.cisco.launcher.y.a(Unknown Source)
at com.cisco.launcher.y.if(Unknown Source)
at com.cisco.launcher.r.a(Unknown Source)
at com.cisco.launcher.s.do(Unknown Source)
at com.cisco.launcher.s.null(Unknown Source)
at com.cisco.launcher.s.new(Unknown Source)
at com.cisco.launcher.s.access$000(Unknown Source)
at com.cisco.launcher.s$2.a(Unknown Source)
at com.cisco.launcher.g$2.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Trying for IDM. url=https://192.168.1.1/idm/idm.jnlp/
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
at com.cisco.launcher.w.a(Unknown Source)
at com.cisco.launcher.s.for(Unknown Source)
Kristian,
If you are getting the same message as in this thread.
https://supportforums.cisco.com/thread/2261710?tstart=0
try these steps that I took and it should work with Jave 7 u51.
1. Go to the ASA IP address in IE.
2. Select Continue to website. (This is where it asks if you want to install the ASDM Launcher)
3. In the Address Bar click on "Certificate Error" then "View Certificates."
4. Go to Details tab and select "Copy to File" and export the cert to my desktop using the default DER format.
5. Open Java Control Panel and go to "Security" tab and "Manage Certificates."
6. Selected "Secure Site" in drop down box and clicked "Import."
7. Select "All Files" in drop down box, and selected the Cert that I exported from IE.
Bob
