ASA5520 Problem
emad.silicon
Hi dear all :
I have a strange problem , when I try to save my configuration on the asa5520 I get the error massege that say
"%Error reading system:/running-config (Configuration line too long)
Error executing command
[FAILED]"
I check the memory and cpu and I fine it is ok and there is a space
so any one can help please?
m.sir
Level 11
Level 11
It looks you are hitting bug CSCsg87808
Taken from Cisco Bug tool
CSCsg87808 Bug Details
'wr mem' fails due to snmp config; Error: (Configuration line too long)
Symptom:
If snmp-server commands are configured, in a rare corner case
the configuration might fail to save to flash and give the error like below:
pix# wr mem
Cryptochecksum: ee8f5816 e1ce1ad7 83151424 f1a3b6fc %Error
Error executing command [FAILED]
Conditions:
The firewall must have snmp-server commands configured and running
version 7.2(1)25 or greater (includes 7.2(2)).
Workaround:
Remove the snmp-server commands from the configuration
-or-
downgrade to a version of code previous to 7.2(1)25
m.sir
Level 11
Level 11
Symptom:
pix# wr mem
Conditions:
Workaround:
-or-
Thank you M.Sir:
Yes the snmp-server command was the problem
I remove the command and it is work ok , so thank you frined I have rate your solution
emad Frag
