ASA5525-X running FTD removed from FMC for some reason
joseponceiii
Hi Cisco community,
Just wondering if anyone here experienced an ASA5525-X running FTD image being removed in FMC for some reason? I have ran the command "show managers" from the CLI and it says "No managers configured". No changes on it but I'm curious if this is normal, although there's an issue currently on FMC and the sensor due to WAN issues (this is only intermittent and I can access the remote device as of this writing). Does anyone know if this is normal if there is some issues on connectivity between FMC and FTD that the "show managers" will show as empty? I haven't tried re-configuring the configure manager add on FTD.
Also, does anyone know if I can retrieve the registration key from the FMC? I can see on some posts that we could use below but I think this only displays the hashed value and not the clear text.
more sftunnel.conf | grep reg_key
Chakshu Piplani
Hi joseponceiii,
This cannot happen automatically, I would definitely suggest looking into audit logs by going into System --> monitoring-->Audit to check the user ID who did it.
Since there are no managers configured trying to figure out the old key would be a waste, even if you had the old key doing a re-registration would push a blank config to the device. You can re-register the device by using a new key, in off hours.
Chakshu
Do rate helpful posts!
Hi @Chakshu Piplani , thanks for the inputs. Just wondering, if the re-registration would push a blank config to the device, will it wipe out all configs including basic IP configuration? And then after the re-registration to the FMC, after re-deploying the access policies to the device will get the FTD back to normal, right? Or are we expecting to re-configure all basic stuffs (IP address, etc.) before re-registration?
Thanks.
Since you had this device previously registered to the same FMC IP address might be there, I have seen it in some scenarios where it gets retained on the FMC, but thing like NAT Policy and security Zones needs to be re-mapped, same ACP can be mapped at the time of registration, but there is a catch to it, if the IP address and zone config is lost, the policy might not deploy properly.
You can try using the same ACP if it doesn't work, create a new one and attach that to the FTD while registration.
Chakshu
joseponceiii
BTW, I don't see any relevant audit logs that did it. So I'm still wondering why it was lost. The only issue is we have a intermittent WAN issue which is on inside network of the FTD.
