CISCO ASA 5505 IDS problem
INEM
I needed to configure my firewall like a IDS to create a log of activity inside the firewall monthly , how I do that?
When I select types of attacks, an error appears saying: No IDS policy is applied to any interface.
How to apply a IDS policy to the interface?
See please the image below..
thanks in advance,
Best Regards
Carlos
rhermes
Level 7
Level 7
YOu can choose to apply your IPS either in Promiscious
or In-Line mode
http://www.cisco.com/en/US/partner/docs/security/asa/asa72/configuration/guide/ssm.html
- Bob
Allen P Chen
Level 5
Level 5
IP Audit needs to be configured before any information will appear under the Logging section.  IP Audit is configured under Configuration>Firewall>Advanced>IP Audit within ASDM.  Here is the configuration guide for IP Audit:
http://www.cisco.com/en/US/docs/security/asdm/6_2/user/guide/protect.html#wp1279781
Hope this helps.
