Cisco ASA 5505 NAT and access rule problem
lawfukyau
Hi all
I have some NAT/access rules problem.
static (inside,outside) 210.90.112.221 192.168.222.4 netmask 255.255.255.255
access-list outside_access_in extended permit tcp any host 219.90.119.237 eq 3389
access-group outside_access_in in interface outside
it is work, But I add other server nat and access rule. server can not get internet and outside can not remote this server. if I del access rule ,it can get internet!!!!!
Who can help me ?
Thanks you very much
11 Replies 11
Jennifer Halim
Can you please advise what NAT rule you have added?
What is the ASA outside interface IP? Hopefully you are not using the same IP Address as the ASA outside interface IP and configure static 1:1 NAT.
If you are going to use the ASA outside interface IP as your NAT, then you would need to configure static PAT instead of static NAT.
Result of the command: "sh run"
: Saved
ASA Version 8.2(1)
hostname xxxxxx
domain-name xxxxxx
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 119.70.109.129 Exch2 description Mon Exchange
name 119.70.109.132 Mail description Mon Xmail server
name 119.70.109.128 MailGateway09 description Mon exchange mail gateway
name 119.70.109.135 TrialRemoteServer description Trial Remote Server
name 119.70.109.134 TrialVmserver description Trial Vmserver
name 119.70.109.136 TrilSQLServer description Tril SQL Server
name 119.70.109.131 WebServer description Web Server
name 119.70.109.133 VmServer description VM Server
name 192.168.222.0 Inside_network
interface Vlan1
nameif inside
security-level 100
ip address 192.168.222.222 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 119.70.199.127 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
domain-name xxxxxxx
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any host 119.70.109.138 eq 3389
access-list outside_access_in extended permit tcp any host TrilSQLServer eq 8082
access-list outside_access_in extended permit tcp any host TrilSQLServer eq 3389
access-list outside_access_in extended permit tcp any host TrialRemoteServer eq 3389
access-list outside_access_in extended permit tcp any host TrialVmserver eq 3389
access-list outside_access_in extended permit tcp any host Exch2 eq 3389
access-list outside_access_in extended permit tcp any host Exch2 eq https
access-list outside_access_in extended permit tcp any host Exch2 eq pop3
access-list outside_access_in extended permit tcp any host Exch2 eq smtp
access-list outside_access_in extended permit tcp any host Exch2 eq www
access-list outside_access_in extended permit tcp any host MailGateway09 eq pop3
access-list outside_access_in extended permit icmp any host WebServer
access-list outside_access_in extended permit tcp any host MailGateway09 eq smtp
access-list outside_access_in extended permit tcp any host WebServer eq 3389
access-list outside_access_in extended permit tcp any host WebServer eq https
access-list outside_access_in extended permit tcp any host WebServer eq www
access-list outside_access_in extended permit icmp any host Mail inactive
access-list outside_access_in extended permit tcp any host Mail eq www
access-list outside_access_in extended permit tcp any host Mail eq 3389
access-list outside_access_in extended permit tcp any host Mail eq pop3 inactive
access-list outside_access_in extended permit tcp any host Mail eq smtp inactive
access-list outside_access_in extended permit tcp any host 119.70.109.126 eq 3389
access-list outside_access_in extended permit udp any host 119.70.109.126 eq domain
access-list outside_access_in extended permit tcp any host 119.70.109.126 eq domain
access-list outside_access_in extended permit tcp any host 119.70.109.130 eq 3389
access-list outside_access_in extended permit udp any host 119.70.109.130 eq domain
access-list outside_access_in extended permit tcp any host 119.70.109.130 eq domain
access-list outside_access_in extended permit tcp any host VmServer eq 3389
access-list outside_access_in extended permit tcp any host 119.70.109.137 eq ftp inactive
access-list outside_access_in extended permit tcp any host 119.70.109.137 eq 3389
access-list inside_access_in remark Implicit rule: Permit all traffic to less secure networks
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 Inside_network 255.255.255.0
static (inside,outside) 119.70.109.137 192.168.222.4 netmask 255.255.255.255
static (inside,outside) 119.70.109.126 192.168.222.2 netmask 255.255.255.255
static (inside,outside) MailGateway09 192.168.222.159 netmask 255.255.255.255
static (inside,outside) Exch2 192.168.222.252 netmask 255.255.255.255
static (inside,outside) 119.70.109.130 192.168.222.1 netmask 255.255.255.255
static (inside,outside) WebServer 192.168.222.231 netmask 255.255.255.255
static (inside,outside) Mail 192.168.222.155 netmask 255.255.255.255
static (inside,outside) VmServer 192.168.222.233 netmask 255.255.255.255
static (inside,outside) TrialVmserver 192.168.222.199 netmask 255.255.255.255
static (inside,outside) TrialRemoteServer 192.168.222.198 netmask 255.255.255.255
static (inside,outside) TrilSQLServer 192.168.222.197 netmask 255.255.255.255
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 119.70.109.125 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http Inside_network 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
Cryptochecksum:78042238af7e1aa1473882a6a683acc1
: end
Thanks for the show run, can you please advise what exactly you have added that have caused the issue?
In 192.168.222.2 Server.  it can not get internet and ping 8.8.8.8 " Request time out."
than del access rule for 119.70.109.126 permit rule ( 3 rules), it can get internet and ping test. and Go to checkip.org ,show correct wan ip.
I have testing 192.168.222.2 and 192.168.222.1, alse have this problem.
Thank !!!! brother.
You might want to check the public ip address itself: 119.70.109.126
The problem is not with the rule. It's with the static NAT that you configure with 119.70.109.126.
I would check if the ASA has an ARP entry for 119.70.109.126, if it does, then this is incorrect. You might want to clear the arp and also clear xlate after you configure any static NAT statement.
Also check on the external router that is connected to the ASA if 119.70.109.126 ARP on the router is the ASA outside interface MAC address.
Jennifer
Thanks for your reply.
Wan ip rage  is not real. I changed some number.
also I have restart ASA and clear xlate ,arp..also can not work.
I only have ASA Firewall, and can not check external router arp table in Data Center.
Thanks!
We can't quite help you if we don't have the correct information as we will just be guessing.
This could point to any problem.
Can you try with any other public IP Address? at this point, we are not very clear where and why exactly it's failing? whether it's due to the conflict in IP address, or an ARP issue, or xlate issue, etc.
Jennifer
I will find Data Center operator check ARP information and clear.
Thanks for your suggest. it may be external router ARP problem.
If also can not work,Can I send to you original config file ?
Thanks.
Sure, feel free.
varrao
Level 10
Level 10
Hi Fuk,
Could you please provide the output of "show run" from the firewall and let me know which Nat statement and Access rule you have applied for the other server??
Varun
Varun Rao
I posted Show run config!
