Cisco ASA licencing problems
HenetOPServices
I'm new with Cisco licencing... I have Cisco ASA 5505 product in home with base licence with 10 hosts limit. More information below.
I bought upgrade "L-ASA5505-10-UL=" to remove hosts limit and I got certificate with PAK. But when I go to Cisco licencing site to get activation key with this PAK I'll get error message below.
Unfortunately I don't have support contract so I can't open Service Request as said.
Any help what to do??
Error message:
Wrong Sku(s) 'L-ASA5505-10-UL=' for 'ASA5505-BUN-K9' : Device contains following licenses 'ASA5500-ENCR-K9'
Serial Number = JMX1526Zxxx
We're  sorry, but the new serial number provided is not the same platform type  as the failed serial number. An upgrade request is not allowed.
If  you would like any assistance in the resolution of this issue, please  open a Service Request using the TAC Service Request Tool
> show version
Licensed features for this platform:
Maximum Physical Interfaces       : 8              perpetual
VLANs                             : 3              DMZ Restricted
Dual ISPs                         : Disabled       perpetual
VLAN Trunk Ports                  : 0              perpetual
Inside Hosts                      : 10             perpetual
Failover                          : Disabled       perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Enabled        perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 10             perpetual
Total VPN Peers                   : 25             perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
This platform has a Base license.
Cheers,
Henri
2 Accepted Solutions
Is it an auto reply, or did someone actually reply? Licensing rep should reply to your email. They would be able to rehost the license for you.
Excellent, thanks for the update.
Pls kindly mark this post answered so others can learn from your question. Thanks.
6 Replies 6
Jennifer Halim
Email licensing@cisco.com, and they would be able to help you with the activation key.
Thanks, I have tried licencing@cisco.com but they only replied with web-links to presales and partner contacts.
I am home user, so to make contact with presales is the last option.
It's quite a generic mail some links but nothing about case itself. I'll try again...
HenetOPServices
Update: I received excellent service from licencing@cisco.com and they were able to solve my problem. Thanks Jovy.
