Cisco FTD 4140 not able to register with Firepower Management 6.1
Pranav Gade
Hi All,
We are having Cisco FRP 4140 box with FTD image 6.0.1, can any one help me how to register Cisco 4140 box to Firepower Management ?
Can anybody tell me step by step procedure with commands in FRP 4140 side?
Thanks in Advance
Oliver Kaiser
Level 7
Level 7
You have so assign an ip address to your mgmt interface and configure the fmc connection with a registration-key matching on both ends
e.g.
> configure network ipv4 manual <ftd-management-ip> <subnetmask> <default-gateway>
> configure manager add <fmc-ip-address> <registratation-key>
You may check registration status using the following command:
> show managers
Oliver Kaiser
Level 7
Level 7
e.g.
> show managers
