Conectivity problem
adampetherick
Community Member
I'm currently setting up a PIX 515e at home as follows:
Cable Modem --> 2621 Router --> PIX --> Switch
The inside port on the PIX is up,up however I can't get the outside to connect.
Here are the config's for the interfaces:
2621:
FastEthernet0/1 is up, line protocol is down
Hardware is AmdFE, address is 0007.eb78.0ba1 (bia 0007.eb78.0ba1)
Internet address is 192.168.1.1/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
PIX:
interface ethernet0 "outside" is up, line protocol is down
Hardware is i82559 ethernet, address is 0011.2013.641b
IP address 192.168.1.2, subnet mask 255.255.255.252
MTU 1500 bytes, BW 100000 Kbit full duplex
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
77 packets output, 4620 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/0)
output queue (curr/max blocks): hardware (0/1) software (0/1)
7 Replies 7
spremkumar
Level 11
Level 11
Hi Adam
Which cable you are using to connect both PIX and the router ?
Are you using cross over or a straight through cable ? Can you change the cable and check ?
regds
a.kiprawih
Level 11
Level 11
Since this only involved line protocol, check the UTP cable type you used to connect the router and PIX? It should be cross-over cable.
AK
Yeah I swapped it and it's showing up, up now, but not got any traffic passing, everything is up, up but inside can't see the www.
GB-HOMENET-PIX-01# sh run
: Saved
PIX Version 6.3(3)
interface ethernet0 100full
interface ethernet1 auto
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 DMZ security50
nameif ethernet3 WAP security50
nameif ethernet4 NOT_USED4 security1
nameif ethernet5 NOT_USED5 security1
hostname GB-HOMENET-PIX-01
domain-name HOMENET
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
logging console debugging
icmp deny any outside
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
mtu WAP 1500
mtu NOT_USED4 1500
mtu NOT_USED5 1500
ip address outside 192.168.1.2 255.255.255.252
ip address inside 172.16.10.2 255.255.255.128
ip address DMZ 172.16.10.129 255.255.255.252
ip address WAP 172.16.11.1 255.255.255.252
no ip address NOT_USED4
no ip address NOT_USED5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address DMZ
no failover ip address WAP
no failover ip address NOT_USED4
no failover ip address NOT_USED5
pdm history enable
arp timeout 14400
global (outside) 1 172.16.10.1-172.16.10.127 netmask 255.255.255.128
global (DMZ) 2 172.16.10.128-172.16.10.254 netmask 255.255.255.128
global (WAP) 3 172.16.11.2-172.16.11.127 netmask 255.255.255.128
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (DMZ) 2 0.0.0.0 0.0.0.0 0 0
nat (WAP) 3 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 172.16.10.10 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
fragment chain 1 outside
fragment chain 1 inside
telnet 172.16.10.0 255.255.255.128 inside
telnet timeout 30
ssh timeout 5
console timeout 0
terminal width 80
: end
2 questions:
Do you have a route on your 2600 router pointing the 172.x.x.x to the pix?
ip route 172.16.10.0 255.255.255.0 192.168.1.2
Why are you using a router at all? You should be able to plug the PIX directly into the cable modem. Set the PIX outside IP to use DHCP and nat to your external interface on the PIX.
I think you need to change the 'global' IP. You should use Public IP here, i.e 192.168.1.x, instead of 172.16.10.x range.
Global is always associated with Public IP when it comes to outside/Internet connectivity. But since your Public IP has 2 hosts for Internet router FastEthernet facing PIX Outside interface (192.168.1.1) and PIX Outside interface (192.168.1.2), you have no choice here but to use Outside interface IP as global.
Use 'global' command with 'keyword' interface to allow internal users/DMZ to go out to Internet.
*192.168.1.0/30 means:
subnet ID: 192.168.1.0
Usable address: 192.168.1.1 - .2
broadcast ID: 192.168.1.3
Your config:
ip address outside 192.168.1.2 255.255.255.252 ---> note this for Outside
ip address inside 172.16.10.2 255.255.255.128 --> internal subnet
Update:
- Remove the exisitng "global (outside) 1 172.16.10.1-172.16.10.127 netmask 255.255.255.128", and changed with:
global (outside) 1 interface
This should work. Just make sure both of your PIX and Internet router can ping each other.
Hope this helps. Pls rate all useful post(s)
AK
Thanks for the reply
My public facing IP is 84.x.x.x which is assigned by my ISP via DHCP.;
Have got the PIX and router pinging each other now but still no axs to the web
It's working now, thanks to dflick advising to get rid of the outside router and using ip address outside setroute.
It's a lot slower now tho than the linksys box I was using before!!
