CONNECTION BETWEEN TWO ASA 5506 -X FIREWALLS
shaig
Hello.i have some problem.I need to connect two ASA 5506 firewall with each other .i have created the schema at packet tracer and then recreated it in real world but the same result
i can not make connection (icmp) behind the other firewall (for example from PC0 to PC1) .I have configured all interfaces. i have configured default routes on routers toward the ASAs. I alsa have written default routes on ASA firewalls toward each other and static routes toward their internal routes.I had checked also NAT config I also added icmp to the default global service policy for inspection and other protocols which i needed.But i can ping only from PC0 To ASA2 4.2.2.2 interface.What i have been missing i can not find
9 Replies 9
GRANT3779
You have mentioned NAT config. Can you provide more information on what is being NAT'd and where.
Configs would help also.
I assume you can Ping to each PC from the local FW and Router?
I can ping from PC0 to ASA-2 4.2.2.2 interface but can not go behind ASA-2
I also can ping from PC1 to ASA-1 4.2.2.1 interface but can not go behind it
my nat config are both on ASA1 and ASA2
ASA-1(config-network-object)# nat (inside,outside) dynamic interface
ASA-2 (config-network-object)# nat (inside,outside) dynamic interface
I suspect it is to do with the return traffic being PAT'd again and causing issues.
You may find that if you run Wireshark on say PC0 and try to ping it from PC1 you will see your icmp traffic reach PC0 with it then replying but not getting back to the source.
My understanding without labbing this up is that the return icmp traffic would be PAT'd again in opposite direction causing it to have a different source address. The asa won't have this 'existing' connection from the icmp inspect config and drop. I think during this icmp flow, at one point the source and destination of the traffic willl be either end of the Outside ASA interfaces, e.g source of 4.4.4.2 and destination 4.4.4.1 / vice versa.
If you want to have connectivity between them i would suggest configuring NAT exemption for the hosts.
It doesn't work as expected because it is designed that way on ASA to deny ping through destined the ASA interface IP address.  See link, https://community.cisco.com/t5/routing/asa-5585-x-unreachable-gateway-between-interfaces/m-p/3839525#M313418
There no way to override that security rule.
@joseph.h.nguyen I think the original request was to ping through the ASAs from PC0 to PC1 - not pinging an ASA interface.
@shaig I assume you pinging the 172.16.10.x IP address of PC1? In which case @GRANT3779 is correct, the traffic would match your dynamic nat rule and be natted, so therefore not respond from the IP address you originally pinged.
Create a no-nat/nat exemption rule on both ASA's or alternatively create a static NAT for each PC.
ASA-2#SH RUNning-config
: Saved
ASA Version 9.6(1)
hostname ASA-2
names
interface GigabitEthernet1/1
nameif OUTSIDE
security-level 100
ip address 4.2.2.2 255.255.255.252
interface GigabitEthernet1/2
nameif INSIDE
security-level 0
ip address 10.2.2.1 255.255.255.0
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network NAT
subnet 172.16.10.0 255.255.255.0
route INSIDE 172.16.10.0 255.255.255.0 10.2.2.2 1
route OUTSIDE 0.0.0.0 0.0.0.0 4.2.2.1 1
object network NAT
nat (INSIDE,OUTSIDE) dynamic interface
telnet timeout 5
ssh timeout 5
ASA-2#
ASA-1#SH RUNning-config
: Saved
ASA Version 9.6(1)
hostname ASA-1
names
nameif outside
security-level 100
ip address 4.2.2.1 255.255.255.252
nameif inside
security-level 0
ip address 10.1.1.1 255.255.255.0
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
object network NAT
subnet 192.168.10.0 255.255.255.0
route inside 192.168.10.0 255.255.255.0 10.1.1.2 1
route outside 0.0.0.0 0.0.0.0 4.2.2.2 1
object network NAT
telnet timeout 5
ssh timeout 5
ASA-1#
ASA-1#sh running-config
: Saved
ASA Version 9.6(1)
hostname ASA-1
names
nameif outside
security-level 100
nameif inside
security-level 0
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
object network NAT
object network NAT
telnet timeout 5
ssh timeout 5
ASA-1#
ASA-2#sh running-config
: Saved
ASA Version 9.6(1)
hostname ASA-2
names
nameif outside
security-level 100
nameif inside
security-level 0
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
object network NAT
route inside 172.16.10.0 255.255.255.0 10.2.2.2 1
route outside 0.0.0.0 0.0.0.0 4.2.2.1 1
object network NAT
telnet timeout 5
ssh timeout 5
ASA-2#
i have pasted the running-config of both ASAs
Hi There,
On ASA1 can you configure the following two objects, obviously stick in the IP addresses for each host.
Object network obj_pc0
Host "pc0 ip address"
Object network obj_pc1
Host "pc1ip address"
Then add the following NAT/NO NAT rule.
nat (inside,outside) source static obj_pc0 obj_pc0 destination static obj_pc1 obj_pc1
Add the same objects on ASA2 but then add the following reverse NONAT.
nat (inside,outside) source static obj_pc1 obj_pc1 destination static obj_pc0 obj_pc0
Test your ping
