CSA and ISS System Scanner
TradeSecrets
I am running CSA 5.1 and ISS System Scanner agent[Assuria Adutior 4.2]. CSA seems to stop the agent from listening for the ISS consoles calls. when CSA is remove the agent functions correctly. CSA will stop sysscan process even in test mode. If anyone has any suggestions, I would greatly appreciate it.
bostonbeerbob
Upgrade to csa 5.2.203 or above.. This problem will go away
brian.mathias
Have you tried removing the network shim to see if the problem still exists?
Just an idea... good luck.
-Brian
Hi Brian,
I found out the problem. I turned off buffer over-flow protection and all my problems went away. I am working with cisco development for a custom fix.
TS
bostonbeerbob
