04-30-2017 08:34 PM - edited 03-12-2019 02:17 AM
What does it means ?
Is there any issue
6 Apr 30 2017 13:51:12 106015 1.1.1.1 443 2.2.2.2 64274 Deny TCP (no connection) from 1.1.1.1/443 to 2.2.2.2/64274 flags ACK on interface Outside
6 Apr 30 2017 13:59:19 106015 1.1.1.1 443 2.2.2.2 21005 Deny TCP (no connection) from 1.1.1.1/443 to 2.2.2.2/21005 flags PSH ACK on interface Outside
6 Apr 30 2017 13:59:15 106015 10.0.10.247 63645 1.1.1.1 443 Deny TCP (no connection) from 10.0.10.247/63645 to 1.1.1.1/443 flags RST on interface Inside
6 Apr 30 2017 13:59:15 106015 1.1.1.1 443 2.2.2.2 63645 Deny TCP (no connection) from 1.1.1.1/443 to 2.2.2.2/63645 flags PSH ACK on interface Outside
Where is 2.2.2.2 my public ip
10.0.10.247 is my local ip address
1.1.1.1 outside ip address
Asa in active satandby mode
04-30-2017 09:33 PM
Not uncommon. It means you received a packet for a connection that does not exist or in a state that is not valid.
04-30-2017 10:38 PM
Is there some reason ,something need to be checked ?
04-30-2017 10:39 PM
Unless there is a considerable quantity of them there is nothing to check. It is a fairly normal thing to see.
