Difference between a router with firewall features and a hardware firewall
duraimurugan
Please explain why we are going for hardware firewalls,since most routers have firewall features,IPS,IDS,stateful inspections of packets.So,what are the additional features in hardware firewall which are unique from routers
vijayasankar
Level 4
Level 4
As you know hardware firewall is a dedicated appliance which acts as as security enforcement point in your network.
The hardware resource is dedicated for that functionality.
Routers having firewall feature set also does the same job, but the hardware capability will be limited in this setup. It will not scale well.
Based on the scenario in question, the option is open for you to choose between both.
For larger deployments typically dedicated firewall appliance is the sure way to go.
-VJ
