Difference between session and connection
alex_ciobanu
Level 2
Level 2
Not sure this is the right place for this, but I am not able to find a proper definition between these 2 terms.
What is the difference between session and connection, theoritically speaking ?
mz331wcisco
Community Member
Hello
In order to get the meaning of terms Connection and Session let's define first the term Flow.
The definition of a Flow is historically accepted as:
A unidirectional sequence of packets between 2 network endpoints that have the following 7 things in common:
1. Source IP address
2. Destination IP address
3. L3 Protocol type
4. Source port
5. Destination port
6. Tos (Type of Service)
7. Input interface
The terms Connection and Session can have many different meanings depending on the framework that they are used, but it can be said that:
Connection: A bidirectional Flow
Session: Many connections between the same source and same destination
5 Replies 5
Kureli Sankar
Alexandru,
If you read here:
A single connection is created for multiple DNS  sessions, as long as they are between the same two hosts, and the  sessions have the same 5-tuple (source/destination IP address,  source/destination port, and protocol). DNS identification is tracked by  app_id, and the idle timer for each app_id runs independently.
Does this make sense?
-Kureli
...Not really
I was looking for a pure theoretical definition, and comparation between.
I would like to know exactly the difference between one and another, because I see many people confusing these 2 terms or even saying the same thing.
mz331wcisco
Community Member
Hello
3. L3 Protocol type
4. Source port
5. Destination port
7. Input interface
To indicate "THROUGH" the box traffic - we use the term connection. ex. FTP connection from inside to outside.
To indicate "TO the box" traffic - we use the term session.  ex. VPN to the outside interface, telnet to the inside interface
Flow VS Session/Connection
Connection will have two flows - forward and reverse flows.
-Kureli
Very Nice Reply Mikis...High 5!!  Thanks   Regards,  Ankur Thukral  Community Manager : Securtiy and VPN
