Dynamic and Static PAT using a single public IP
stevenilan
I'm trying to configure PAT on a new ASA-5510 running 9.0(3) and I'm having some issues.
In our setup we have a single public IP address(lets say 127.1.1.1) which is assigned to the outside interface, and we need to use that for both dynamic PAT to allow all machines in our 10.1.0.0 255.255.255.0 subnet hit the outside world, as well as allow the outside world FTP access to (10.1.0.124) on the inside using static PAT.
I have dynamic PAT working and we are able to hit the outside world, but I can't get the static service PAT working to forward FTP traffic.
The configuration looks like this right now:
object network obj-10.1.0.124
    host 10.1.0.124
object network obj-10.1.0.0
    subnet 10.1.0.0 255.255.255.0
nat (infra,outside) source dynamic obj-10.1.0.0 interface
    nat (infra,outside) static interface service tcp 21 21
Should the dynamic PAT rule also be written as a network object rule?
Thanks!
Steve
5 Replies 5
manish arora
Level 6
Level 6
That looks correct, just add another static PAT for TCP port 20 as well.
Here's a link to a useful Doc :
https://supportforums.cisco.com/document/33921/asa-pre-83-83-nat-configuration-examples
Manish
Thanks for your reply.  It isn't working though so I'm not sure what the problem is, adding another PAT translation for port 20 did not help either.
Please post the output of the following :
show nat detail
show run nat
Manish
Thanks for your help Manish, I figured it out.
-Steve
stevenilan
Changing the global PAT to an object PAT rule got everything working correctly.
object network obj-ftp-access
 host 10.1.0.124
 nat (infra,outside) dynamic interface
