EXPERT HELP PLEASE: ASA tcp flow terminated by inspection engine
bsetexast
I recently upgraded to 8.2 and now I see this message. I also have trouble http'ing to some websites. In particular yahoo.com! Google, cisco, Microsoft...no problem. Its very concerning. I do not recall seeing this message with 7.X. See the alerts below, any help would really be appreciated.
Jun 12 2009 10:44:39: %ASA-4-507003: tcp flow from inside:x.x.x.x/4759 to outside:x.x.x.x/80 terminated by inspection engine, reason - inspector reset unconditionally.
Jun 12 2009 10:44:43: %ASA-4-507003: tcp flow from inside:x.x.x.x/2047 to outside:x.x.x.x/80 terminated by inspection engine, reason - inspector reset unconditionally.
Jun 12 2009 10:44:51: %ASA-4-507003: tcp flow from inside:x.x.x.x/2048 to outside:x.x.x.x/80 terminated by inspection engine, reason - inspector reset unconditionally.
plumbis
Level 7
Level 7
This is a cosmetic issue with web filtering enabled causing double logging of block messages.
Try configuring "no logging message 507003" as a workaround.
