Firepower 2100 running Transparent Mode
latenaite2011
Level 4
Level 4
Just wondering if the 2100 Firepower appliance is running in transparent mode and we allow all traffic through, how does it protect the traffic from malicious activity?
2 Accepted Solutions
You just select the Default Action as shown below when creating your Access Control Policy:
Since it is not terminating the VPN it can do very little other than confirm that the packets conform to the IPsec protocol specification.
7 Replies 7
Marvin Rhoads
Even if you don't have any block rules in your access control policy you should at the very least have a default Intrusion policy and use the Security Intelligence feed.
Most customers use the "balanced security and connectivity" intrusion policy. That intrusion policy will block intrusions with CVSS score 9 or greater from the current and past 2 years.
Please refer to Cisco Live presentation BRKSEC-3300 for more details.
Thank you for respond to this.
How should the default intrusion policy look like?
I should allow all traffic through so that it will get inspected and the
intrusion policy will block intrusions with CVSS score 9 or greater?
Thank you Marvin.  It was helpful.
Just curious if the Firepower can inspect Site-to-Site VPN through the Firepower.  Is there anything special that needs to be for it?
Ok, thank you Marvin.
