FTD With FDM Hardening Settings (SSH/Console Timeout, Banner)
taro75
I am using FTD 1120 using Firepower Device Manager, please advise on the easiet method to set these settings
I need to set the following
a) SSH timeout
b) Console timeout
c) SNMP settings
d) Login Banner
Here look into the section Prohibited CLI command, using flexobjects ssh command is prohibited.
please do not forget to rate.
6 Replies 6
Sheraz.Salim
you have not mentioned what FTD version you on
The only solution to enable and configure SNMP feature via FDM is to use FlexConfig Policy https://www.ciscozine.com/configure-snmp-firepower-fdm/
FTD Banner Here
FTD 1120 version is 7.0.5-72
@MHM Cisco World  The link you provided is for FMC. Whereas the question asked is for FMD.
How to set SSH timeout in FDM? I am able to set console timeout from flexobjects but not for ssh.
