FTDv in Azure stuck in shell mode
mateens
Have deployed FTDv in Azure. Not able to add  to FMC because it is stuck in shell command prompt. ftdv :~$ . How do i get ftd command prompt ?
Marvin Rhoads
Odd. My FTDv deployments have only been on ESXi. They always give me the clish command prompt (">").
If you "exit" from the Azure console cli, what do you get?
6 Replies 6
Marvin Rhoads
Are you accessing via the Azure console or via ssh?
Yes, via Azure Console. Did ssh from Azure console to FTD also and ssh to FMC box and then FTD getting the same prompt. Seems like i am in but cannot see the correct firepower cli.
Marvin Rhoads
its is Azure "Serial Console"
I get connection closed. Like i was already connected.
my bad, I was using the wrong user to login....issue is solved.
samuesan
This can mean you are logged in with a user account that doesnt have the proper privileges, however typing in "clish" from the ftdv :~$ prompt can get you into the > prompt you are looking for.
