Help to configure port translation for RDP
GoldTipu
Hello All
I am new here so i need some help .
I have a RDP Server inside (LAN ) (192.168.1.73)
I have a Cisco ASA inside (192.168.1.1)
I wanted to access the RDP server from outside
But NOT from the default port ..........   i want to use 4488 port from outside
(See screen shot )
Like if i do RDP from outside on port 4488
 i want ASA to translated to RDP port 3389 and directed to my RDP server inside.
I have already opened port 4488 in my firewall
(See screen shot )
How can configure NAT rule ?
so i can access my RDP server from outside on port 4488 and it will be automatically redirected to RDP 3389 ?
Please guide me on ASDM (I am new with this firewall )
m
balaji.bandi
below command level should able to give you what you looking :
object network RDP-Host
host 192.168.1.73
access-list outside_access_in extended permit object RDP any any
nat (any,outside) static interface service tcp 4488 3389
BB
balaji.bandi
host 192.168.1.73
BB
Thank you here is CLI output.
ciscoasa(config)# object network RDP-Host
ciscoasa(config-network-object)# host 192.168.1.73
ciscoasa(config-network-object)# access-list outside_access_in extended permit$
WARNING: <outside_access_in> found duplicate element
ciscoasa(config)#
ciscoasa(config-network-object)# nat (any,outside) static interface service tc$
but when i am trying RDP from ouside on port 4488 it failed .
screen shot .
please advise .
i changed this and its working ............. SUPER THANKS.............
nat (any,outside) static interface service tcp  3389 4488
balaji.bandi
Glad all working, I may be miss-typed otherway around, good you able to figure it out. thank you for the resolution.
BB
