Help with troubleshooting Firepower FTD VPN not passing traffic
mhmservice
Hi all
I am currently building a proof of concept with the following topology. It is all built inside a single VMware ESXI host.
I intend to configure a full mesh VPN between all four FTD devices to route between the LAN subnets (10.1.0.0/24,10.2.0.0/24,10.3.0.0/24,10.4.0.0/24)
I have a basic "hide" NAT rule setup from inside to outside on each FTD and there is an "any-any" access control policy in place on all the firewalls to rule that out as an issue
PC 10.2.0.111 can ping the outside interface of FTD1 so I know the connectivity through R1 is working. The FMC can also connect to FTD2,FTD3,FTD4 management interfaces over R1 as they have been configured using this connection
The issue is I can't seem to ping the sites from each other, e.g. PC 10.2.0.111 is unable to ping 10.1.0.111. I have checked windows firewall is turned off on the VMs.
Here is the full mesh VPN config page from FMC:
image.pngI thought the problem was the NAT policy so I configured as follows to try to get connectivity to work on FTD1:
And on FTD2:
Show crypto ikev2 sa on FTD1 shows the tunnel (all other FTDs show similar)image.png
I ran a trace and it says the traffic is allowed:
Does anyopne have more tips on how to troubleshoot this as i'm really stuck
All help appreciated
2 Accepted Solutions
Double check that FTD2 PC has FTD2 inside interface as its gateway. That's the routing that is suspect given your output that you shared.
Finally fixed it ... subnet mask on PC 10.2.0.111 was set to 255.0.0.0 not 255.255.255.0 ...
Stupid mistake on my part, but a mystery solved!
Thanks for the hints
10 Replies 10
matty-boy
Do you have access control policies to permit the traffic?
I have the following policy on all FTD devices in place in an attempt to troubleshoot this:image.png
run a packet tracer to verify it first.
least it will tell you where the packet the droping
please do not forget to rate.
I ran the following packet tracer and it says "DROP" for ipsec-tunnel-flow but im not sure what specifically that means
i think you packet trace does not give accurate result in terms of vpn.
can you sent constant ping from Site1_Lan to Site2_Lan in mean time check if phase 1 and phase 2 come up.
if you have access to CLI on FTD give command
show crypto ikev1 sa
show crypto ipsec sa
Sure
FTD1:
FTD2:
can you please double check if the routing is properly in place. i can see the encap and no decap. most probably it could be a routing issue.
I think that it is:
FTD1:
FTD2:
