Host inside ASA 5510 configuration problem.
Charlie Taylor
Level 4
Level 4
We have a Citrix host behind a new 5510 that needs to be accessed by the public. I have tried to follow the examples on cisco.com but still continue to get errors. I KNOW I am missing something simple. I have taken out all my 'tries' and have basic config below with errors.
I am new to PIX/ASA and would live some suggestions on the proper Access Group and corresponding ACL to get the 192.168.71.100/72.54.197.26 Citrix server to accept ssl from outside.
ASA Version 7.0(8)
interface Ethernet0/0
description Outside interface to Cbeyond
nameif OUTSIDE
security-level 0
ip address 72.54.197.28 255.255.255.248
interface Ethernet0/1
description Inside interface to internal network
nameif INSIDE
security-level 100
ip address 192.168.72.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.71.2 255.255.255.0
management-only
object-group service Citrix1494 tcp
port-object eq citrix-ica
port-object eq www
port-object eq https
port-object range 445 447
nat-control
global (OUTSIDE) 1 interface
nat (INSIDE) 1 0.0.0.0 0.0.0.0
static (OUTSIDE,INSIDE) 192.168.72.100 72.54.197.26 netmask 255.255.255.255
static (INSIDE,OUTSIDE) 72.54.197.26 192.168.72.100 netmask 255.255.255.255
route OUTSIDE 0.0.0.0 0.0.0.0 72.54.197.25 100
http server enable
http 192.168.71.0 255.255.255.0 management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Error Log:
3|Apr 15 2011 21:06:07|305005: No translation group found for tcp src INSIDE:192.168.72.75/57508 dst OUTSIDE:72.54.197.26/443
3|Apr 15 2011 21:06:01|305005: No translation group found for tcp src INSIDE:192.168.72.75/57508 dst OUTSIDE:72.54.197.26/443
3|Apr 15 2011 21:05:58|305005: No translation group found for tcp src INSIDE:192.168.72.75/57508 dst OUTSIDE:72.54.197.26/443
5|Apr 15 2011 21:05:42|111008: User 'root' executed the 'no access-list OUTSIDE_access_in extended permit tcp host 72.54.197.26 host 72.54.197.26' command.
4|Apr 15 2011 21:05:20|106023: Deny tcp src OUTSIDE:114.38.58.208/2817 dst INSIDE:72.54.197.26/445 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:05:17|106023: Deny tcp src OUTSIDE:114.38.58.208/2817 dst INSIDE:72.54.197.26/445 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:04:37|106023: Deny tcp src OUTSIDE:221.1.220.185/12200 dst INSIDE:72.54.197.26/1080 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:03:50|106023: Deny tcp src OUTSIDE:32.141.52.12/1787 dst INSIDE:72.54.197.26/443 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:03:44|106023: Deny tcp src OUTSIDE:32.141.52.12/1787 dst INSIDE:72.54.197.26/443 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:03:41|106023: Deny tcp src OUTSIDE:32.141.52.12/1787 dst INSIDE:72.54.197.26/443 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:02:23|106023: Deny tcp src OUTSIDE:32.141.52.12/1785 dst INSIDE:72.54.197.26/443 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:02:17|106023: Deny tcp src OUTSIDE:32.141.52.12/1785 dst INSIDE:72.54.197.26/443 by access-group "OUTSIDE_access_in"
4|Apr 15 2011 21:02:14|106023: Deny tcp src OUTSIDE:32.141.52.12/1785 dst INSIDE:72.54.197.26/443 by access-group "OUTSIDE_access_in"
5|Apr 15 2011 21:01:56|111008: User 'root' executed the 'access-list OUTSIDE_access_in line 1 extended permit tcp host 72.54.197.26 host 72.54.197.26' command.
6|Apr 15 2011 21:00:13|302013: Built outbound TCP connection 7173 for OUTSIDE:150.70.85.65/443 (150.70.85.65/443) to INSIDE:192.168.72.100/2959 (72.54.197.26/2959)
6|Apr 15 2011 20:56:57|302016: Teardown UDP connection 7082 for OUTSIDE:72.54.197.26/137 to INSIDE:192.168.72.17/137 duration 0:02:01 bytes 62
6|Apr 15 2011 20:55:19|302013: Built outbound TCP connection 7088 for OUTSIDE:184.85.253.178/80 (184.85.253.178/80) to INSIDE:192.168.72.100/2879 (72.54.197.26/2879)
6|Apr 15 2011 20:55:19|302013: Built outbound TCP connection 7086 for OUTSIDE:74.125.159.147/80 (74.125.159.147/80) to INSIDE:192.168.72.100/2878 (72.54.197.26/2878)
6|Apr 15 2011 20:54:55|302015: Built outbound UDP connection 7082 for OUTSIDE:72.54.197.26/137 (192.168.72.100/137) to INSIDE:192.168.72.17/137 (72.54.197.28/24)
6|Apr 15 2011 20:54:17|302021: Teardown ICMP connection for faddr 10.160.68.225/0 gaddr 72.54.197.26/1 laddr 192.168.72.100/1
6|Apr 15 2011 20:54:15|302020: Built outbound ICMP connection for faddr 10.160.68.225/0 gaddr 72.54.197.26/1 laddr 192.168.72.100/1
6|Apr 15 2011 20:54:13|302021: Teardown ICMP connection for faddr 172.28.16.2/0 gaddr 72.54.197.26/1 laddr 192.168.72.100/1
6|Apr 15 2011 20:54:12|302013: Built outbound TCP connection 7074 for OUTSIDE:199.7.52.190/80 (199.7.52.190/80) to INSIDE:192.168.72.100/2815 (72.54.197.26/2815)
6|Apr 15 2011 20:54:12|302013: Built outbound TCP connection 7073 for OUTSIDE:199.7.55.72/80 (199.7.55.72/80) to INSIDE:192.168.72.100/2813 (72.54.197.26/2813)
6|Apr 15 2011 20:54:12|302013: Built outbound TCP connection 7072 for OUTSIDE:199.7.55.72/80 (199.7.55.72/80) to INSIDE:192.168.72.100/2812 (72.54.197.26/2812)
6|Apr 15 2011 20:54:12|302013: Built outbound TCP connection 7071 for OUTSIDE:199.7.52.190/80 (199.7.52.190/80) to INSIDE:192.168.72.100/2811 (72.54.197.26/2811)
6|Apr 15 2011 20:54:12|302013: Built outbound TCP connection 7070 for OUTSIDE:184.85.253.19/80 (184.85.253.19/80) to INSIDE:192.168.72.100/2810 (72.54.197.26/2810)
3|Apr 15 2011 20:54:12|106014: Deny inbound icmp src OUTSIDE:172.28.16.2 dst INSIDE:72.54.197.26 (type 0, code 0)
6|Apr 15 2011 20:54:11|302020: Built outbound ICMP connection for faddr 172.28.16.2/0 gaddr 72.54.197.26/1 laddr 192.168.72.100/1
6|Apr 15 2011 20:54:10|302013: Built outbound TCP connection 7063 for OUTSIDE:64.4.18.90/80 (64.4.18.90/80) to INSIDE:192.168.72.100/2809 (72.54.197.26/2809)
3|Apr 15 2011 20:52:17|305005: No translation group found for tcp src INSIDE:192.168.72.75/56624 dst OUTSIDE:72.54.197.26/443
3|Apr 15 2011 20:52:11|305005: No translation group found for tcp src INSIDE:192.168.72.75/56624 dst OUTSIDE:72.54.197.26/443
3|Apr 15 2011 20:52:08|305005: No translation group found for tcp src INSIDE:192.168.72.75/56624 dst OUTSIDE:72.54.197.26/443
2|Apr 15 2011 20:50:02|106001: Inbound TCP connection denied from 187.28.118.35/1973 to 72.54.197.26/445 flags SYN  on interface OUTSIDE
2|Apr 15 2011 20:49:59|106001: Inbound TCP connection denied from 187.28.118.35/1973 to 72.54.197.26/445 flags SYN  on interface OUTSIDE
2|Apr 15 2011 20:49:58|106001: Inbound TCP connection denied from 184.27.73.83/443 to 72.54.197.26/60784 flags RST  on interface OUTSIDE
2|Apr 15 2011 20:49:58|106001: Inbound TCP connection denied from 184.27.73.83/443 to 72.54.197.26/60783 flags RST  on interface OUTSIDE
2|Apr 15 2011 20:49:58|106001: Inbound TCP connection denied from 184.27.73.83/443 to 72.54.197.26/60781 flags RST  on interface OUTSIDE
2|Apr 15 2011 20:49:58|106001: Inbound TCP connection denied from 184.27.73.83/443 to 72.54.197.26/60782 flags RST  on interface OUTSIDE
2|Apr 15 2011 20:49:58|106001: Inbound TCP connection denied from 184.27.73.83/443 to 72.54.197.26/60779 flags RST  on interface OUTSIDE
2|Apr 15 2011 20:49:58|106001: Inbound TCP connection denied from 184.27.73.83/443 to 72.54.197.26/60785 flags RST  on interface OUTSIDE
2|Apr 15 2011 20:49:35|106001: Inbound TCP connection denied from 217.10.43.52/1486 to 72.54.197.26/445 flags SYN  on interface OUTSIDE
2|Apr 15 2011 20:49:32|106001: Inbound TCP connection denied from 217.10.43.52/1486 to 72.54.197.26/445 flags SYN  on interface OUTSIDE
3|Apr 15 2011 20:48:17|305005: No translation group found for tcp src INSIDE:192.168.72.97/55593 dst OUTSIDE:72.54.197.26/443
3|Apr 15 2011 20:48:11|305005: No translation group found for tcp src INSIDE:192.168.72.97/55593 dst OUTSIDE:72.54.197.26/443
3|Apr 15 2011 20:48:08|305005: No translation group found for tcp src INSIDE:192.168.72.97/55593 dst OUTSIDE:72.54.197.26/443
THANKS!!
varrao
Level 10
Level 10
Charlie,
First of all the static command doesn't seem correct, you just do not need the destinastion nat, so delete the following command:
Static commands are bi-directional, so you do not need it.
Then make sure you have a route for it on the ASA:
route 192.168.72.0 255.255.255.0
Then:
access-list outside_access extended permit tcp any host 72.54.197.26
and it should work after that.
Let me know how it works.
Varun
Varun Rao
