How to monitor IP NAT Pool for ASA (Firepower ASA Appliance)
jewfcb001
Level 4
Level 4
Hi All,
I would like to monitor IP NAT POOL If IP NAT Pool Full how can monitor this situation ? Is it trigger or send log for Nat Pool Full ?
balaji.bandi
there are couple ways :
1. if you have enabled syslog to syslog server, it will give an error when the pool exhausted.
example : %ASA-3-202010: [NAT | PAT] pool exhausted for pool-name, port range
2. you can run command (show nat pools)frequently  out of box script make a graph or alerts
3. or you can use SNMP polling if you have any NMS in Place and get alerts based on threshold.
BB
balaji.bandi
BB
jewfcb001
Level 4
Level 4
@balaji.bandi
Thank you for your information . For Answer Number 3 what is the SNMP polling for IP Nat Pool Full ?
balaji.bandi
SNMP :
1.3.6.1.2.1.123.1.4.1.19. natAddrMapAddrUsed
But i you may have differ results snmp polling vs real time show nat pool - because it changes dynamically.
BB
jewfcb001
Level 4
Level 4
@balaji.bandi
Thank you so much.
