How to power up IDSM-2
v.nastase
I have Cat6509 with IDSM-2 in PwdDown state.
How can I power up the blade ?
Thanks in advance for your help
a.arndt
Level 3
Level 3
I believe issuing a reset command to the IDSM-2 from the Catalyst’s CLI will do this.
The following information was taken from the online installation guide: (http://www.cisco.com/en/US/products/sw/secursw/ps2113/products_installation_and_configuration_guide_chapter09186a008035809d.html)
Catalyst Software
To reset the IDSM-2 from the CLI, follow these steps:
Step 1 Log in to the console.
Step 2 Enter privileged mode:
Console> enable
Step 3 Reset the IDSM-2 to the application partition or the maintenance partition:
Console> (enable) reset module_number [hdd:1/cf:1]
Cisco IOS Software
Router# configure terminal
Step 3 Reset the IDSM-2:
Router# hw-module module module_number reset [hdd:1/cf:1]
I hope this helps,
Alex Arndt
I tried with:
sw# hw-module module 8 reset
but the response was
module 8 is operationally off (Module Failed SCP dnld)
Unfortunately, I don't have a lot of experience with this.
You have, IMHO, two options at this point:
1) Wait for an answer to your post from a more knowledgeable member of the forum (or Cisco); or,
2) Open a TAC case and get immediate support.
The choice is yours. Sorry I cannot be of any help...
Alex Arndt
marcabal
Cat OS: set module power up
Native IOS: power enable module
