How to troubleshoot when there is problem on PIX?
ahpark78
I am trying to figure out how to troubleshoot,example, how to get the log from the PIX or any URL that is useful on this troubleshooting section..
thanks in advanced.
ken
m.sir
Level 7
Level 7
You can turn on logging with commands
logging enable
logging timestamp
logging buffered informational
You can verify log with command
show logg
Check this link
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a2e04.shtml
M.
zubairjalal
A good doc from cisco is attached. It basically will guide you in case you want to troubleshoot the pix firewall say in cases of performance degradation.
--Pls rate if it helps--
