Lan and State failover - benefits of separate interfaces?
johnnylingo
Level 5
Level 5
I've typically configured both LAN and State failover for the ASAs via the same physical interface.  For example on an ASA5510:
failover
failover lan unit primary
failover lan interface FAILOVER Ethernet0/3
failover link FAILOVER Ethernet0/3
failover interface ip FAILOVER 192.168.0.1 255.255.255.252 standby 192.168.0.2
I'm now upgrading to the -X series, and since they have more physical interfaces, I'm wondering if there's any advantage to configuring stateful failover information on a separate interface?  Like this:
failover lan interface LAN_FAILOVER GigabitEthernet0/4
failover link STATE_FAILOVER GigabitEthernet0/5
failover interface ip LAN_FAILOVER 192.168.0.1 255.255.255.252 standby 192.168.0.2
failover interface ip STATE_FAILOVER 192.168.1.1 255.255.255.252 standby 192.168.1.2
Hello Johnyy,
Can you please share what you understood from this? and which one should be used?
Or if I say I want to enable statefull failover so that when my Primary firewall goes down, all the connection information should be passed to secondary set and secondary to act as active one. For this do I need to enable both Lan failover as well as link faiolver?
I doubt if failover link only helps in sharing connection information to secondary firewall. and lan failover is allways needed to check state of primary firewall.
This means ASA use this Ethernet 0/3 interface to monitor failover through hello messages. This determines which unit is going to be Active or Standby. Also used for configuration replication.
You should monitor the stateful traffic in your environment. If its heavy, its better to use a dedicated link for failover.
You can use any available and unused interface other than Ethernet 0/3 for stateful traffic exchange
Example:
failover link FAILOVER Ethernet0/1
We can configure IPSEC tunnel or failover key command to encrypt message exchange.
Thank you.
