Monitoring & management of IPS module on ASA
network770
I have a number of aip-ssm modules on a number of asa's and it's becoming very 'painful' to login to each module to check the logs.
is there a tool that can capture all the logs and notify us when things go bad?
5 Replies 5
Allen P Chen
Level 5
Level 5
Have you looked into IPS Manager Express (IME)?
http://www.cisco.com/en/US/partner/prod/collateral/vpndevc/ps5729/ps5715/ps9610/data_sheet_c78-459033.html
It is available for download here:
http://tinyurl.com/67g4zdy
Hope this helps.
Does IME cost or is a free tool?
Mick
It is a free download if you have a support contract.
Hope this helps.
But IME will support only 10 IPs devices(keep in mind).
Rajeswar.
