nat and route issue
elite2010
Level 3
Level 3
I have the below topology
asa fw running in active standby mode
R1 and R2 are routers which is conneced to isp's
In R1 and R2  hsrp is running
R1
interface gi0/1
 ip address 4.4.4.2   255.255.255.252 -connected to isp  router 1
interface GigabitEthernet0/2
 ip address 1.1.1.2  255.255.255.0 (connected to sw1 from switch  to asa1  outside interface )
ip route 2.2.2.0 255.255.255.0 GigabitEthernet0/2
router bgp 60000
 network 1.1.1.0  mask 255.255.255.0
 network 2.2.2.0 mask 255.255.255.0
 neighbor 4.4.4.4 remote-as 52578
 neighbor 4.4.4.4 ttl-security hops 1
 neighbor 4.4.4.4 timers 5 20 20
R2
interface gi0/1
 ip address 4.4.4.5   255.255.255.252 -connected to isp router 2
 ip address 1.1.1.3  255.255.255.0 (connected to sw2  from switch  to asa2  outside interface )
router bgp 60000
Asa outside interface ip
I did  a static nat  2.2.2.100 to 192.168.2.10 ( Verified route from asa inside interface )
It did not work .
From R1  did a traceroute to 2.2.2.100 . Which shows a loop
Tracing the route to 2.2.2.100
VRF info: (vrf in name/id, vrf out name/id)
  1 (1.1.1.3) 0 msec 0 msec 0 msec  (R2 -gi0/1 whcih is connected to ASA 2  through sw2 )
  2 4.4.4.6[AS XXXX] 4 msec 0 msec 4 msec (connection to ISP from R2 )
  3 4.4.4.1 [AS XXXX] 0 msec 0 msec 0 msec  (connection to ISP from R1 )
  4 4.4.4.2 [AS XXXX] 0 msec 0 msec 4 msec (R1 -gi0/1 whcih is connected to ASA 1  through sw1 )
  5  (1.1.1.3) 0 msec 0 msec 0 msec
  6 4.4.4.6[AS XXXX] 4 msec 4 msec 0 msec
  7 4.4.4.1 [AS XXXX] 4 msec 4 msec 0 msec
  8 4.4.4.2 [AS XXXX] 4 msec 0 msec 4 msec
On the ROUTER R1 ,arp shows the 2.2.2.100's mac address can reach through R2'S gi0/1 . (2.2.2.100 mac address  in the arp table is the iinterface GI0/1's mac address )
Itried to clear the arp table but no use
Thansks
15 Replies 15
I copy paste your exact config and I'm not able to do a traceroute on 2.2.2.100 because your acl outside is allowing only http and https:
R1#traceroute 2.2.2.100
1 * * *
2 * * *
3 * * *
4 *
ASA logs:
3|Dec 23 2017 23:52:01|106014: Deny inbound icmp src Outside:1.1.1.2 dst inside:192.168.2.10 (type 8, code 0)
3|Dec 23 2017 23:52:02|106014: Deny inbound icmp src Outside:1.1.1.2 dst inside:192.168.2.10 (type 8, code 0)
However, if for testing i modify the acl into a permit ip any any, everything is working:
1 2.2.2.100 8 msec 4 msec *
The following route on ASA isn't needed: route Outside 2.2.2.0 255.255.255.0 1.1.1.1 1
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
