NAT problem, anyconnect clients cant reach dmz?
3moloz123
ASA 8.3
Anyconnect users can reach INSIDE, but not DMZ. Dmz host 10.120.1.2 is what I am trying to reach.
Packet-tracer shows it should be possible. Attaching my asa config.
What am I missing?
¨Packet-tracer:
asa-kalasa# packet-tracer input vpn tcp 172.16.32.4 50545 10.120.1.2 22
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   10.120.1.0      255.255.255.0   dmz
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group dmz_access_in in interface dmz
access-list dmz_access_in extended permit ip any any log disable
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group dmz_access_out out interface vpn
access-list dmz_access_out extended permit ip any any log disable
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 32484740, packet dispatched to next module
Result:
input-interface: dmz
input-status: up
input-line-status: up
output-interface: dmz
output-status: up
output-line-status: up
Action: allow
On the Nat statements, instead of using the Any Any use the object groups for each network like:
nat (inside,outside) source staticy OFFICE-NET  OFFICE-NET  destination static NETWORK_OBJ_172.16.32.0_24 NETWORK_OBJ_172.16.32.0_24
Same for the DMZ
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
6 Replies 6
3moloz123
Bumping this thread. Surely, someone must be able to help me debug this further?
I have isolated the problem to these two rules:
6 (inside) to (outside) source static any any destination static ipsecvpnpool ipsecvpnpool
    translate_hits = 4997, untranslate_hits = 34889
5 (dmz) to (outside) source static any any destination static ipsecvpnpool ipsecvpnpool
    translate_hits = 0, untranslate_hits = 0
Here, anyconnect can reach inside, but not dmz. If I however change the order of the nat rules, then anyconnect can reach dmz but not inside.
Same for the DMZ
Julio
Julio Carvajal
Hi jcarvaja!
That did indeed work. Im not sure why any any wouldn't be as good as a match, as it clearly must differ on what interface the packet comes in on. Anyway, thank you for the answer,
Hello 3moloz,
Glad to hear I could help! yeap usually the any any on a nat statement causes a lot of issues do to arp problems.
Julio
Julio Carvajal
TianXia
Spoiler
I have the same problem in 9.24.
object network inside
 subnet 10.0.0.0 255.255.255.0
 nat (inside,outside) dynamic interface
object network dmz
 subnet 172.16.0.0 255.255.255.0
 nat (dmz,outside) dynamic interface
object network vpnpool
subnet 10.0.1.0 255.255.255.0
creat vpnpool for Anyconnect Client Address-Pool
If you only do these, Anyconnect Client only reaches inside the network. So I use twice nat solved it.
nat (inside,outside) source static inside inside destination static vpnpool vpnpool
nat (dmz,outside) source static dmz dmz destination static vpnpool vpnpool
Anyconnect Client any reach Both of Inside&DMZ network
