NAT problem, only nat traffic against wan interface
3moloz123
Level 4
Level 4
Got multiple vlans, some of them have internal subnets. I only want to SNAT the traffic from vlans with internal subnets that have destination on wan interface.
vlan580 = 10.10.10.0/24
vlan581 = 1.2.8.0/24
With this, vlan580 cant reach vlan581
access-list vlan580_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_58 172.16.20.0 255.255.255.0
access-list vlan580_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_58 10.10.10.0 255.255.255.0
nat (vlan580) 0 access-list vlan580_nat0_outbound
nat (vlan580) 1 0.0.0.0 0.0.0.0
But, removing the 'nat (vlan580) 1 0.0.0.0 0.0.0.0' makes it work. So how can I exempt vlan581 (and a list of other vlans)?
Jennifer Halim
Can you please share the security level for both vlan580 and vlan581?
You can configure NAT exemption from high to low security level interface,ie:
assuming that vlan 580 has higher security level than vlan 581, you can add the following access-list:
access-list vlan580_nat0_outbound extended permit ip 10.10.10.0 255.255.255.0 1.2.8.0 255.255.255.0
and acl: vlan580_nat0_outbound has been applied to: nat (vlan580) 0 access-list vlan580_nat0_outbound
However, if vlan 580 has lower security level than vlan 581, then you would need to configure the following (assuming that you don't have any NAT 0 with ACL applied to vlan581 already):
vlan581_nat0 extended permit ip 1.2.8.0 255.255.255.0 10.10.10.0 255.255.255.0
nat (vlan581) 0 access-list vlan581_nat0
If you however have NAT 0 for vlan581, just add to the access-list with the above permit from "1.2.8.0 255.255.255.0" to "10.10.10.0 255.255.255.0"
Hope that helps.
