NAT problem with PIX 515E
giamwi
I have configured a PIX 515E, OS 7.0(1) f?r dynamic PAT from the inside network to the outside interface ip address of the PIX. I have also configured access lists allowing icmp from inside to outside and from outside to inside. All traffic (www, dns, ftp, etc.) works fine except ping. Whenever I do a ping from an inside host to any address outside, I get the following error messages:
6|Aug 24 2006 11:10:52|609002: Teardown local-host outside:193.222.224.104 duration 0:00:10
6|Aug 24 2006 11:10:52|302021: Teardown ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/9 laddr FDFR001/8994
6|Aug 24 2006 11:10:50|302021: Teardown ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/8 laddr FDFR001/8993
4|Aug 24 2006 11:10:50|106023: Deny icmp src outside:193.222.224.104 dst inside:212.203.90.59 (type 0, code 0) by access-group "outside_access_in"
6|Aug 24 2006 11:10:50|302020: Built ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/9 laddr FDFR001/8994
6|Aug 24 2006 11:10:48|302021: Teardown ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/7 laddr FDFR001/8992
4|Aug 24 2006 11:10:48|106023: Deny icmp src outside:193.222.224.104 dst inside:212.203.90.59 (type 0, code 0) by access-group "outside_access_in"
6|Aug 24 2006 11:10:48|302020: Built ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/8 laddr FDFR001/8993
6|Aug 24 2006 11:10:46|302021: Teardown ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/6 laddr FDFR001/8991
4|Aug 24 2006 11:10:46|106023: Deny icmp src outside:193.222.224.104 dst inside:212.203.90.59 (type 0, code 0) by access-group "outside_access_in"
6|Aug 24 2006 11:10:46|302020: Built ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/7 laddr FDFR001/8992
6|Aug 24 2006 11:10:44|302021: Teardown ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/5 laddr FDFR001/8990
4|Aug 24 2006 11:10:44|106023: Deny icmp src outside:193.222.224.104 dst inside:212.203.90.59 (type 0, code 0) by access-group "outside_access_in"
6|Aug 24 2006 11:10:44|302020: Built ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/6 laddr FDFR001/8991
4|Aug 24 2006 11:10:42|106023: Deny icmp src outside:193.222.224.104 dst inside:212.203.90.59 (type 0, code 0) by access-group "outside_access_in"
6|Aug 24 2006 11:10:42|302020: Built ICMP connection for faddr 193.222.224.104/0 gaddr 212.203.90.59/5 laddr FDFR001/8990
6|Aug 24 2006 11:10:42|609001: Built local-host outside:193.222.224.104
What might be the problem?
Thanks, Meg
Actually, you only have to allow the echo replies from any to any on the outside interface... If you make the following ACL on the outside, it should work...
access-list outside_access_in extended permit icmp any any echo-reply
Fernando_Meza
Level 7
Level 7
Hi .. by the look of it it seems your access-list outside_access_in is blocking the icmp reply packets ( icmp type 0 )
You have 2 options either specically allow icmp any any on the access-list applied to the interfaces or enable icmp inspection which is disabled by default and allow icmp any any on the access-list appied to the inside only.
ICMP is a connectionless protocol and so the ASA only creates unidirectional sessions by default which must be specically allowed on the source and destination ( inside/outside) interfaces.
I hope it helps ... please rate it if it does !!!
