Need help with port forwarding
Kopoly
I'm trying to open smtp on my ASA-5505.  My software version is ASA 9.2(4) and ASDM 7.5(2).  Here is what I did:
I created this access rule:
access-list outside_access_in line 1 extended permit tcp any object obj-192.168.1.20 eq smtp
access-group outside_access_in in interface outside
And did the following NAT
nat (inside,inside) 1 source static obj-192.168.1.20 interface service any SMTP-Service-Object, where SMTP-Service-Object is smtp.
When I send the following packet tracer:   packet-tracer input outside tcp 127.217.5.115 25 192.168.1.20 25 xml
The packet is dropped right after ROUTE-LOOKUP with error "Slowpath security check failed."
What am I doing wrong?
Thanks in advance,
Kanwaljeet Singh
Hi Nader,
Why is your nat rule (inside, inside). Shouldn't it be nat (inside,outside)?
Kanwal
Note: Please mark answers if they are helpful.
