Needs basic help with asa5505
k.lundgren91
Community Member
Hello!
I just started my new job at a company ( finally made it to change my line of work it IT )!
Here's the problem, They have already setup a working network before me and my boss wants to keep that network working but i need to set up a basic switch to asa5505 to connect a ( atm only one but will be more hence the switch ) ftp server to it and grant it access to internet but im new to this kind of gear *still learning*.
SO i was hoping someone has a bit of free time over and can guide me to open that switch to the internet but still closed off to the rest of the network without f'ing up the old config.
Yeah and btw, would be easiest / best if i could do it from COM port because thats how it's connected atm
Sincerely New guy!
11 Replies 11
Marius Gunnerud
Do the FTP servers need to be accessed from the internet or do they just need access to the internet?  Also, what license is your ASA running (Base license or security plus license).  Issue the show version command to get this info.
is it a layer 3 switch or layer 2. and how many subnets do you have in your network.  Do they just need to be seperated from the FTP servers or also from eachother?
Please remember to select a correct answer and rate helpful posts
the ftp servers is going to be used as online storage for all employees so i guess only accessed from the internet.
Base License
Is there a command i issue to get you all the info you need?
Sincerely
Are you going to place the server in a DMZ so you can filter traffic for internal users also or will it be placed on the inside network?
i want it to be placed outside all networks for security reasons and there is no reason to have it internal since the company server computer will have another network cable going to the internal network on differnet subnet, But ill try to not make a fool of myself by making this:
Server 1 will be for employees only
Server 2,3 will be for renting out etc.
Where is the ASA coming into play in your network diagram here?  I am assuming the red boxes?
If the ASA is just going to sit between the internet and the servers and not route or touch any traffic from the office computers then you could do a simple configuration like the following just remember to change the interfaces, IPs passwords, host names, etc. as needed.  Also, be sure to use passive FTP, not active.
hostname ciscoasa
domain-name home.local
enable password PASSWORD
interface Ethernet1/1
description Internet
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet1/2
description Office Computers
nameif Inside
security-level 100
ip address 10.1.2.1 255.255.255.0
object network OFFICE_SERVER1_Private
host 10.1.2.10
object network OFFICE_SERVER2_Private
host 10.1.2.11
object network OFFICE_SERVER1_Public
host 11.11.11.10
object network OFFICE_SERVER2_Public
host 11.11.11.11
object network OFFICE_COMPUTERS
subnet 10.1.2.0 255.255.255.0
nat (inside,outside) dynamic interface
nat (inside,outside) source static OFFICE_SERVER1 OFFICE_SERVER1_Public
nat (inside,outside) source static OFFICE_SERVER2 OFFICE_SERVER2_Public
access-list outside_access_in permit tcp any host 10.1.2.10 eq 21
access-list outside_access_in permit tcp any host 10.1.2.11 eq 21
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 11.11.11.1
username NAME password PASSWORD
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
aaa authentication serial console LOCAL
ssh 10.1.2.0 255.255.255.0 inside
http server enables
http10.1.2.0 255.255.255.0 inside
i think you missunderstood, i just want to configure a port on the asa 5505 router that i can plug into a switch and have all the ftp servers on. and its atm configured alrdy so i just want to "add" to the config to a physical port on the router, can i write something in the terminal and copy here that shows how's it configured?
Ok, Then the interface configuration you want would be something like this just replace the vlan in the no forward command to your inside network, and change the interface vlan do the desired VLAN number.  NAT and ACL configuration will differ depending on if you are running ASA version 8.2 or earlier or 8.3 and higher.  Here is an example of what you could do to grant access to FTP servers from the internet.
interface vlan3
no forward interface vlan 1
description SERVERS
nameif DMZ
security-level 50
no shut
object network SERVERS_privarte
  host 10.1.2.10
  nat (inside,outside) static interface service tcp ftp ftp
access-list outside_access_in permit tcp any host 10.1.2.10 eq ftp
Cisco Adaptive Security Appliance Software Version 8.4(2)
VLAN Name Status Ports
1 inside up Et0/1, Et0/2, Et0/3, Et0/4
Et0/5, Et0/6, Et0/7
2 outside up Et0/0
any other command i should type and post ? since im worried im gonna break something in the existing config for the equipment already connected to it *im not allowed to change so that dosnt work*
a thousand thanks so far mate, you are gold!
I am getting emails that there have been updates to the discussion but when I come to the discussion page I do not see any updates.  I have sent a mail to support and asked them to check this.
Did you delete your reply ? 😞
EDIT: nvm.. the forum bugged out
Cant help 😕 ?
Sincerely
