PIX 501 port problems
Terry6674
I have an old PIX 501 that still needs to open ports 80 and 443 for external access to my internal 192.168.1.10 computer. I can't figure out where I'm going wrong, any feedback would be greatly appreciated.
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxx
passwd xxxx
hostname pixfirewall
domain-name anyplace.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 100 permit ip 192.168.1.0 255.255.255.0 172.16.0.0 255.255.255.0
access-list outside permit tcp any host xxx.xxx.xxx.xxx eq www
access-list outside permit udp any host xxx.xxx.xxx.xxx eq 80
pager lines 24
logging on
logging standby
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 10.x.x.x.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool test 172.16.0.1-172.16.0.254
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) xxx.xxx.xxx.xxx 192.168.1.10 netmask 255.255.255.255 0 0
access-group outside in interface outside
conduit permit icmp any any
conduit permit esp any any
conduit permit udp any eq isakmp any
route outside 0.0.0.0 0.0.0.0 10.1.10.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 30 set transform-set myset
crypto map newmap 20 ipsec-isakmp dynamic dynmap
crypto map newmap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd dns xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxx
I have a static IP through a cable modem.
9 Replies 9
rais
Level 7
Level 7
I assume you have a router in between your modem and the Pix.
On your router, do you have in-bound port 80 traffic, forwarded to your web-server's port 80?
Thanks.
I have a Cisco UBR (provided by the ISP) as a modem that connects directly to my 501. The UBR has everything open, as it gives all access control over to the 501.
What UBR model are you using? Does it have some public IP address?
Has your ISP assigned you one special IP for your web-server?
Try to remove access-lists and see if you are able to connect.
Can you ping your public IP from web? Go to: http://lg.broadwing.net/looking/ and see if you can ping.
Thanks.
if you are using 10.x.x.x on the outside of the pix, then the pix is behind something that is doing NAT. you will need to tell your ISP that you do not want the ubr to do nat most likely
jonathanstevens
There are couple of questions here...
This access-list includes your internal host (and network)
Then you apply nat 0 to this....
This means your internal network is not translated as it exits the PIX (which I am assuming is connected to the internet on a single IP) when it's going to 172.16 networks (which I suspect your ISP would drop). So I'm not sure why that's there?
Assuming that xxx.xxx.xxx.xxx is your internet interface it looks basically ok.
However, if you internal host is not using DHCP it shouldn't be in the DHCP range you have identified.
If it is using DHCP, you can't guarantee it will always have the right IP address. Which is the case?
If you setup
logging monitor debug
then
term mon
and try a connection from the outside what does the session show?
OK, My ISP provided me with a uBR905. They questioned my configuration also, and as I am just a newbie, I explained that the management here wanted the VPN capability (which is turned on, I just omitted it from the 'wr t' I posted earlier).
The ISP (Comcast) then opened all the ports on the uBR and let my 501 call all the shots. I can ping my static IP address, but I can't access my File Server (which is static at 192.168.1.10 and uses the ports 80 and 443).
If there is some pruning that needs to take place, great, but I'm not sure what everything is for. I do know that the uBR's outside is the static IP address, the inside is 10.1.10.1. On the PIX, the outside is 10.1.10.2 and the inside is 192.168.1.1
Do you suggest I remove the nat(inside) 0 access-list 100 line?
This looks like a pretty nice product and supports NAT:
http://www.cisco.com/en/US/products/hw/cable/ps2221/products_configuration_guide_chapter09186a008007cf8f.html#10297
You need to configure NAT statment on your UBR such that port 80 traffic goes to 192.168.1.10. It will be something like:
ip nat inside source static tcp 192.168.1.10 80 w.x.y.z 80
Where your public IP (w.x.y.z) is available here:
http://www.netdept.com/ipandhost.jsp
Also you may be able to use 'interface cable-modem0' instead of IP address. Use '?' in router to get help on ip nat, etc.
Thanks.
This is the config:
Internet --- uBR905 ---- PIX501 ----- Fileserver
uBR (outside - w.x.y.z, inside 10.1.10.1)
Pix (outside -10.1.10.2 inside 192.168.1.1)
I bypassed the PIX and went straight through the uBR's port and it worked fine, so I know the uBR's configured to pass 80 & 443 TCP & UDP. This verifies the PIX is the sole holdup.
What lines do I need to modify to allow the PIX to pass (both ways) 80 & 443 to 192.168.1.10?
You already have the following line in your config:
Temporarily open it for any host in your network and see if that works. For https simply add another line with 443 instead of www.
HTH.
