Pix 515E and 7.0 HTTP problem!
michael.crocker
We currently have a Pix 515E firewall that sets between a Catalyst 4006 on the inside and two 3745's with internet access configured as HSRP peers on the outside.
We upgraded the firewall to the new 7.0 version of software and we started to have internet access problems. Pages wouldn't load or they would load extremely slow. You would try to go to the same page again shortly thereafter and it would pop right up.
Has anyone seen this problem or are familiar with a setting in the new 7.0 that could cause this that I'm overlooking? I did turn off a log of the policy "fixup" stuff and this didn't seem to help. Any ideas would be greatly appreciated.
nkhawaja
turn on syslogs and capture them, see if that shows any issue. are you using URL filtering?
have you tried to disable dns fixup
thanks
Nadeem
No URL filtering. It didn't act abnormal until we upgraded from 6.3.4 to 7.01. I'll check and see if that works. Thanks for the help.
