PIX 515e with two internal networks; PAT problems
gullevek1
I have PIX 515e with OS 6.3(4) and I have one outside and two inside networks.
right now I have these settings (config excerpt):
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 half security50
access-list inside_access_in permit ip any any log interval 1
access-list half_access_in permit ip any any log interval 1
access-list outside_access_in permit ip any any log interval 1
global (outside) 10 interface
global (inside) 10 interface
global (half) 10 interface
nat (inside) 10 192.168.0.0 255.255.0.0 0 0
nat (half) 10 172.16.0.0 255.255.0.0 0 0
when I have this, I can access the internet from both sides, and I can access half from inside. But when I try to access inside from half it doesn't work (of course lower sec to higher). So I try to add this:
nat (half) 10 172.16.0.0 255.255.0.0 outside 0 0
but then I can't connect from inside to half anymore and I get "305005 No translation" error messages.
What do I do wrong? How can i have bi-directional PAT for the half interface.
sachinraja
Level 9
Level 9
hello gullevek
for accessing from half to inside, you need to do a nonat for the traffic between these two networks... do the following and try:
nat (inside) 0 access-list nonat
access-list nonat permit ip 192.168.0.0 255.255.0.0 172.16.0.0 255.255.0.0
remove the second nat statement u had added.
no nat (half) 10 172.16.0.0 255.255.0.0 outside 0 0
dont have an ip any any access-list. i hope this is just for testing..
Raj
So there is no way, that the traffic from Half to Inside gets also Masqueraded (PAT, with nat ... outside?).
