Pix firewall 506 - static (inside outside) problem
sunilbk
i am connected the server behand the firewall..
firewall ip address -outside - 64.170.x.1 inside -192.168.1.1
IIS server A -ip address inside -192.168.1.2 outside - 64.170.x.2
above server working fine and also i have
IIS server B ip address -64.170.x.3 which is not behand firewall.and also its working fine. now i shifted this server behand the firewall
i given inside 192.168.1.3 outside 64.170.x.3 - now from out side we cannot access the server all configuration is same as above server.
is it happening b'cause of before this ip address is outside the firewall?
i clear the arp also but not working.any help
Sunil Kolkur
bdube
Level 2
Level 2
Did you change the default gateway of your IIS server B to point to the firewall's internal interface ?
Ben
yes i did change the default gateway of iis server B,same problem
server cannot access outside firewall...and from outside we cannot access that server..any help
