PIX stateful failover problem
antonio.sobreiro
Community Member
I have 2 cisco PIXs with the last sw 6.2. The are in failover and they have have also stateful failover (with RJ45 cable). When the primary PIX goes down and the secondary goes up(than it becomes the primary) all connections stay alive unless the connections that uses the 2049 port (Network File System - Sun Microsystems) the NFS port.
Can someone help me?
Antonio Sobreiro
apriore685
Level 2
Level 2
Not sure what you queston is. If the primary fails over and becomes the seconday than all is well.
all the connections stay alive but thae connections with 2049 ports goes down.
Perhaps the timeout values for your NFS configuration are too low.
