PIX upgrade from Single unit to failover mode Question
arvindsa
We have PIX 505E currently and we want to replace it with PIX 515E UR FO [failover bundle].
How easy is to transfer the config from PIX 505E to PIX 515E UR , like can we tftp from 505 to TFTP and then import it in 515?
Any other suggestion is welcome...
thanks in adance
flyingmunk
i'm assuming that you mean a 506E. anyway, the easiest way would be to just cut and past the config from your 506 to the new 515. you may have to make some changes to the interface settings/config, but other than that, you should have not problems.
thanks,
chris
