Please help with PIX 501 basic configuration...
j.rock
Community Member
Please, could you help me with basic config with access from inside network 192.168.1.0/24 to outside network 192.168.7.0/24. I have problem with icmp(ping) from inside to outside and other serveces as ftp and http on outside host 192.168.7.1. This is my config...(I'm biginer) 🐵
(192.168.1.2 is my comp)
Result of firewall command: "sh runn"
: Saved
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname firewall
domain-name firewall.cz
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list inside_access_in permit icmp any any
access-list outside_access_in permit icmp any any
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 192.168.7.2 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.2 255.255.255.255 inside
pdm history enable
arp timeout 14400
nat (inside) 0 192.168.1.0 255.255.255.0 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
rip outside default version 1
rip inside default version 1
route outside 0.0.0.0 0.0.0.0 192.168.7.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 192.168.1.2 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxx
: end
pcomeaux
So here's the things that I check:
1 - How are interfaces setup:
This is setup ok.
2 - What are the IP addresses on the interface:
This is setup ok.
3 - What does the routing look like:
This is setup ok.
4 - What does the NAT look like:
This is setup not to translate the 192.168.1.0 hosts as they pass through the pix.
5 - What Access-Groups are applied to the interfaces:
This is setup ok.
6 - Since Access-Groups are applied to the interfaces, what do the Access-lists look like:
This is when I notice something peculiar.
In your attempt to get ICMP working, you modified the Pix's default behavior that allows all connections from the inside to go out. In the access-list inside_access_in, you've limited traffic that arrives on the inside interface to just ICMP. You need to use PDM to permit ip any any or whatever you would like to flow through the Pix from the inside to the outside.
Give this a try and let us know what happens.
thanks
peter
j.rock
Community Member
Peter, please, could you send me some basic config example, where is allows icmp traffic? My config still doesn't working. I have 6.3(4) IOS in PIX501.
Thank you...
m.sir
Level 11
Level 11
Did try ICMP command?
For example in global configuration mode
icmp permit any unreachable outside
icmp permit any echo-reply outside
bhatok
Level 3
Level 3
I'm not sure about the 2 Access list commands you currently have so I'd get rid of them and the 2 access group commands. You can do this by entering the same commands except put a "no" in front of it.
no access-list inside_access_in permit icmp any any
Use this instead:
access-list 1 permit icmp any any echo-reply
access-group 1 in interface outside
This allows any replies from ping requests to come through the outside interface.
