port range from outside to inside
gary.grobe
For an ASA 5505 and I need to open up a range of ports from 28300 - 28400 and 28600 - 28700, all for access from the outside interface to any machine on the inside interface. Can anyone help out with this?
# sh running-config
: Saved
ASA Version 7.2(4)
hostname ciscoasa
enable password 8HgaP2T2asdbjsx1GBdq encrypted
passwd Ku287h/3Z9f25tj6 encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh scopy enable
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:9977cf711682d26e5ca49800ac4e94c0
: end
Nagaraja Thanthry
Are you doing it for a specific application? I see from your configuration that you are using dynamic PAT. So, there is no point in opening those ports as they will not be mapped to any device. I would suggest you using inspects for opening those ports dynamically (as long as it is one of the standard applications supported by the firewall).
Hope this helps.
NT
Yeah, it's specific for a Matlab application. I will soon add a static IP to the outside interface. It's basically a default config right now.
As long as you are assigning public IP to every host that needs the port to be opened, then you can use the following statement:
access-list permit tcp any host range 28300 28400
access-list permit tcp any host range 28600 28700
You need to repeat the above lines for every host.If every inside device has a corresponding public IP and you want it to be open for everybody, then replace the "host public IP" by "any".
Hope this helps.
NT
