Possible to use geo location to block access to remote access VPN?
Jack G
I tried to create a ACL which was configured as source zone and destination zone both outside with a source IP as my public IP action deny, but once applied, I can still access the VPN signin page. Is there a way to block access to remote VPN from specific IPs?
Thank you!
7 Replies 7
balaji.bandi
if this firepower Geo based ACL possible, if this ASA ( i am afraid as far as i concernt it available on ASA code)
BB
Yes, it's a FTD firewall managed by FMC running the latest 6.5 code. I'm trying to research and perhaps it needs to be a control panel access control instead of the typical ACL rule? Not sure how or if a control panel ACL can be configured with FMC/FTD?
    Use flexconfig to deploy a control-plane AC; if it doesn't work, open a TAC case and mention this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn78593/?rfs=iqvred
Cristian Matei.
Could you give us some hint how the flexconfig configuration should be?
Konstantinos
I'm using geo ACL rules else where and it works fine. I just can't restrict access to VPN landing page which is hosted from the firewall outside interface.
Try @Cristian Matei  suggested flexconfig, if that is feasible for you.
BB
