Problem FW asa 5512 for HA
Dhikra Marghli
Level 5
Level 5
Hello
we have two device ASA CISCO 5512 with HA  (  primary and secondary ).
so i have problem :
FW1-Primary ( Active )
FW2-secondary ( Failed )
and it is we have an error message
one device is unknown state
you will find two pictures about error mesage :
Please , i need from expert security reply me and help me about this problem
2 Accepted Solutions
balaji.bandi
if this is working one Failed or new setup :
Either case, check is the device online, by console, check the cables between devics. try to reload secondary and check.
BB
@Dhikra Marghli check the INSIDE interface on the secondary ASA.
This host: Secondary - Failed
 Active time: 0 (sec)
 slot 0: ASA5512 hw/sw rev (3.0/9.9(2)88) status (Up Sys)
 Interface diagnostic (0.0.0.0): Normal (Waiting)
 Interface INSIDE (0.0.0.0): No Link (Waiting)
Check and replace the cable, check the interface configuration on the switch is correct. Attempt to ping the interface IP address.
5 Replies 5
@Dhikra Marghli has this ever worked?
Can you please run "show failover" and "show failover history" and provide the output.
Hello
you will find an attachment  that contains outpout for two commands :  show failover" and "show failover history"
thanks to chek and i wait a reply for this problem
balaji.bandi
BB
Thanks to check
