09-10-2013 03:05 PM - edited 03-11-2019 07:36 PM
We have an ASA 5520 with various different DMZ's at different security levels. One of the interfaces, gi0/2, is configured with sub-interfaces connected via a trunk to a 3560 switch. I am trying to pass traffic from VLAN 4 to the inside network with limited success. For some reason traffic for VLAN 4 is getting blocked by the acl for VLAN 2. Is this a NAT issue?
192.168.193.4 | 192.168.17.195 | Deny icmp src dmz2:192.168.193.4 dst inside:192.168.17.195 (type 0, code 0) by access-group "acl_dmz2" [0x0, 0x0] |
192.168.17.195 | 1 | 192.168.193.4 | 0 | Built outbound ICMP connection for faddr 192.168.193.4/0 gaddr 192.168.17.195/1 laddr 192.168.17.195/1 |
Here is the interface configuration:
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/2.1
vlan 2
nameif dmz2
security-level 60
ip address 192.168.19.1 255.255.255.0
interface GigabitEthernet0/2.2
vlan 3
nameif dmz3
security-level 30
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/2.3
vlan 4
nameif dmz4
security-level 90
ip address 192.168.193.1 255.255.255.248
interface GigabitEthernet0/3
nameif inside
security-level 100
ip address 192.168.17.1 255.255.255.0
nat (dmz4) 1 192.168.193.0 255.255.255.248
Solved! Go to Solution.
09-10-2013 06:22 PM
You are right.
For some reason the packets are getting to interface dmz2 instead of VLAN4. Are you running routing on the switch?
Mike
09-10-2013 04:05 PM
Hi;
Can we have a look at the access-lit acl_dmz2?
Mike
09-10-2013 06:16 PM
acl_dmz2 shoukld have nothing to do with this? I have not edited acl_dmz2 to allow or permit any traffic associated VLAN 4 under subinterface gi0/2.3. All traffic on gi0/2.3 should be controled by acl_dmz4, not acl_dmz2. acl_dmz2 should only control traffic on gi0/2.1. I wouldn't think it would have anything to do with traffic on any other sub-interface.
09-10-2013 06:22 PM
You are right.
Mike
09-10-2013 06:27 PM
No, IP routing is not enabled but the native vlan for the trunk is default at vlan 1.
09-10-2013 06:30 PM
Can you do a quick capture on the ASA? Do the following:
capture dmz2 interface dmz2 match icmp host 192.168.193.4 host 192.168.17.195
Then do the ping and then do, "show cap dmz2 detail" check the mac address of the source of the packet and you will be able to see who is sending the packet to the incorrect vlan.
Mike
09-10-2013 06:40 PM
Ok, I'll do this once I get back to the office in a few days.
