Problem with VPN after upgrade.
boschrexroth
I have just upgraded my PIX 515 to 7.1.2 and now my VPN tunnels connect but they do not allow me to see any of my network. They worked fine with 6.3.3.
It seems to be either a routing issue or a ACL issue as I can create the tunnel but I cannot access/ping anything on my network.
Here is my sho isakmp sa.
Active SA: 4
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 4
1 IKE Peer: 78.179.155.21
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
2 IKE Peer: 33.64.128.21
3 IKE Peer: 43.57.209.21
Type : user Role : responder
Rekey : no State : AM_ACTIVE
4 IKE Peer: 111.34.145.21 Type : L2L Role : responder
Thanks.
anton_lva
Your configuration, please!
I figured it out.
During the upgrade to 7.1 it removed my
nat (inside) 0 statement.
Now everything works fine.
